Supercharged ls1. Please help
Hey guys my name is Mike. I just bought a 1998 Chevy Camaro z28 6-speed with 70k. The only mods are a Vortec supercharger, kooks headers, short throw shifter, and flowmaster exhaust. Still has the stock airbox.
I just bought eibach lowering springs, new airbox, valves and retainers, and a comp cam (231/235 .617"/.621" 114LSA+3).
Ive noticed that the rear end has a slight leak, the rear main seal has a slight leak, as well as the steering rack. It needs shocks, and a driver side outer tie rod end.
Im wondering the common problems with these cars, especially putting 500rwhp to them, and im wondering what I should do to make the car be able to handle 500rwhp, like rear end tranny and clutch. And any other things you guys could tell me would be great. I want to be at 500rwhp safely.
THANK YOU GUYS!
THANK YOU GUYS!
you can replace the rear main seal when you remove the tranny .or take the whole engine out .you will need a valve job if replacing valves.start looking for a HD rear end .check out Bob at brute speed.taking the engine out allows for R&R of the steering rack.how much boost is the blower set up for ?what size injectors and fuel pump do you have ?consider some better rod bolts if the bottom end is all stock .
I'm at 449 rwhp and I'm already upgrading everything.. I did one piece drive shaft. Eaton tru track rear end a d looking into full suspension. When our cars start getting into the power range of our numbers then expect the stock stuff to give out eventually especially with hard driving.
LS1Tech Sponsor
Thanks, I appreciate it. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
