ls1 rockers arms- anyone used these?
Old 12-14-2013, 01:23 PM
chris rojo's Avatar
Smile ls1 rockers arms- anyone used these?
Hello,
I am a newbie, rebuilding my Ls1 motor. The motor will be mated to an A4. Got a great deal on Forged Pistons and H - rods. Crank only needs to be polished.
The top end is Stock 243 heads, with a Texas Speed camshaft and spring kit.
Cam is the 224R (224/224, .581/.581, 114 LSA) Going with new GM LS7 Lifters #12499225
For the Rockers arms - any suggestions - I found these and was wondering if anyone has used these.
http://carshop.carshopinc.com/produc...47/SSILS/HP/RA
Also, ColoradoSpeed has a LS1 Rocker arm retro kit that uses the Comp Cams trunnion kit.
Thanks for the recommendation.
Rojo
Old 12-14-2013, 01:44 PM
2000PewterT/A's Avatar
Stock rockers with the Comp trunnion upgrade is what I use and recommend. I can't speak on the quality of these I have never seen them or used them.
Old 12-14-2013, 01:55 PM
1FastBrick's Avatar
Those look like some type of re-designed stock replacement set up.
I wonder how well the bearings are retained. Looks like a press fit. If thats the case the shield could come off and you lose the bearings just like a factory set up.
Old 12-16-2013, 04:26 AM
2002kirk's Avatar
I would say stay with your stock rocker's and do the trunion upgrade. perfect combination for what you are putting together and will be doing with the car.
Old 12-18-2013, 09:08 PM
XiWastedYouthiX's Avatar
you can also look at the Harland sharp trunion upgrade
Old 12-19-2013, 11:24 AM
spiderlilly's Avatar
In my opinion a rocker arm is a rocker arm. but just like anything else it depends on what kind of hell you are putting them through. but if i had to choose lunati has some pretty wicked setups for a pretty good price.
Quick Reply: ls1 rockers arms- anyone used these?
