where can I buy oem replacement ls main cap bolts?
As title says I am looking for oem replacement main cap bolts. I've search all over the net with no results. I bought a short block that had been torn down, didn't have the bolts. Is there any place I can buy stock bolts, I do not want to but the arp stud kit.
Just talked to the guy I bought it from ( I work with him) said he's almost sure he knows where the bolts are. My question is will it be okay to reuse these bolt since I won't have any idea which hole each of the bolts came out of.
You can reuse them if your friend finds them. It doesn't matter what hole they came out of. Just add some hi-temp RTV silicone to the side bolts so they don't leak, if your reuseing them. New side bolts will have some on them from GM.
If your friend can't find them you can get them from your local dealer or give a few sponcers a call ---------------------------------------------------------------->>>
