ls6 parts compatible with ls1?
basically can i use all the parts below without needs fro adapters or modifications on a 2000 firehawk ls1 that will be getting an ls6 cam and ls6 intake. all parts pulled from the same 2005 CTS-V
LS6 Yellow Beehive Springs
LS6 Push Rods
LS6 Oil Pump
LS6 Rockers
LS6 Timing set (gears + chain)
LS6 Injectors
LS6 Push Rods
LS6 Oil Pump
LS6 Rockers
LS6 Injectors
as in the cam sensor in the ls6 is different than the ls1? if so i dont see it being an issue since im throwing these parts on a ls1. alot of people have done the "hotcam" swap which is the ls6 camshaft. never saw that being an issue. i was told the ls6 pushrods which are different lengths, were better tho for the ls6 camshaft. would this be an issue using the stock ls1 heads and not the 243's that came on the CTS-V's.
naw, not for just a hotcam. you would only need to change your rods if you were going with a custom grind or something along those lines of a "FAT LIFT". I know several ppl who went hotcam being all stock.
