SFC pre drilled holes in under body
Since sub frame connectors didn't come stock on 4th gens, why did GM have those two pre drilled holes on each side of the under body (front of the car) for them to bolt into? What were these holes originally intended for?
There are three holes up front per side, you'll see these kind of holes all around the unibody. I think its probably drain holes so water doesn't get stuck and rust out everything.
holes in rear:
holes in front with sfc bolt bracket installed:
holes in rear:
