abs inop after cam
abs inop after cam
after my cam install, while driving the car my abs inop light comes on and the asr light stays on and low traction comes on, is this a normal prolbem and how can it be fixed thanks
cruising, when i start the car everthing works fine then i'll be driving it and the abs inop light come on, and i cant turn traction control off, and the low traction light will come on sometims
check your connections. There is no way that you could have fried anything on the ABS system by installing a cam. Did you disconnect anything on the system?
Try disconnecting the red lead on the bat for 5 min..See if it goes away.
