Sealing new shifter
Sealing new shifter
Hello I'm just curious what you guys use to seal your shifter to the t56 transmission. I noticed the GTO shifter has a gasket where the Trans Am calls for RTV sealant. I just got a new Pro 5.0 and I'm just wondering what you guys tend to use.
Just for some added info I'm doing an LS1/T56 swap in my 240sx. I have an 04 GTO pull out and I'm converting to an f-body shifter due to fitment issues with the GTO shifter. I removed the entire GTO shifter assembly and swapped out the little cast piece that the shifter sets in for an f-body one so the shifter will fit properly. So at this point, I've noticed the gasket is only available from the dealer and its $45, but I can probably get away with reusing my old one. Just wondering what the forum suggests.
Used blue RTV when I did my clutch because thats what was in the garage, black RTV 2 years later when I had the transmission rebuilt this spring, I used it for the same reason, it's what I had on hand. I see no reason to buy an expensive gasket.
