Need Some Help Please
Old 06-01-2004, 09:29 PM
Rick'SSOM's Avatar
Default Need Some Help Please
Ok did a seach & found out that my 99 a4's shift **** is held on with a clip in the front,my ? is how do I get that damn clip out?
Any help woul be great
Rick
Old 06-01-2004, 09:31 PM
BADFNZ-383's Avatar
u should be able to get at the back of the clip with a small straight screwdriver, and pull it right out. or get a hold of it with a pair of pliers and pull it out. either way should work
Old 06-01-2004, 09:38 PM
Danny2tek's Avatar
needle nose pliers should get it out
Old 06-01-2004, 09:48 PM
Rick'SSOM's Avatar
yeah I did that but nothing,guess im going to easy with it?
thanks
Old 06-01-2004, 10:21 PM
Danny2tek's Avatar
you should just be able to pull it straight out
Old 06-01-2004, 11:38 PM
floman's Avatar
Turn your ignition key to the on position and put the shifter all the way down in 1st gear, this will give you more room to get a good view of what your doing. Like the others said use a small flat blade screwdriver and pry it out. Should come right out.
Old 06-02-2004, 04:49 PM
Rick'SSOM's Avatar
Thats all,I got it out ,it just took a lttle thing called effort.
