pusher fans install
pusher fans install
Hey guys, I purchased a set of 2 10" push/pull fans to run in place of my stock setup. I install the fans on my griffin radiator, i tapped the fans into the stock wiring, started my car and let it idle for 10 minutes, noticed when my fans kicked on they were pulling, so i shut the car off and switched to wires on the fan, they still were pulling when I started the car back, I took my fans and tested them with a battery and the fans do work both push/pull depending on the wiring, any ideas? are the stock relays causing this or what?
