04 GTO Swap Questions gauges?
Old 04-27-2015, 04:08 PM
happydaze's Avatar
Default 04 GTO Swap Questions gauges?
Just getting ready to start my project. Have a 64 Olds Cutlass I am transplanting an 04 GTO LS2 into.
Motor and Trans came complete with CPU and all wiring:
I am hoping I can utilize an 04 GTO gauge set. I may be way off base, but I am thinking the following will work?? I purchased one that included wire pigtail and is for an Auto Trans which mine is.
Things I assume will work with the gauge cluster:
Should plug into the Transmission
Should read all motor sensors
Tach should work
Speedo should work
Concerned about the following if the above is true.
1. I am wondering if I add a 04 GTO fuel sending unit the gas gauge will work? Have an aeromotive in-tank kit for fuel delivery, but wondering what I am needing to get the gauges to work.
2. Will I have tons of error codes? Airbags, seatbelts, crap I am forgetting..
3. Is there an ignition component I need to figure out?
Thanks in advance for any help or suggested links for this conversion.
Brian
Old 04-27-2015, 08:07 PM
kwhizz's Avatar
You will need the GTO Fuel pump for the ECM to read the fuel level........You will also need the BCM and the PIM......
Ken
Old 04-28-2015, 11:41 AM
Atl_monte's Avatar
Where are the BCM and PIM located on the 04 GTO
Old 04-28-2015, 11:55 AM
happydaze's Avatar
Default Pim?
I found plenty of used BCM's on EBay. I assume any is good to go? These aren't specific to AT/Man transmissions or anything funky?
Forgive my ignorance.. But what the hell is a PIM? Plug in Module? Maybe the plug from the ECM to the BCM?
Old 04-28-2015, 03:33 PM
kwhizz's Avatar
PIM ......Partstrain Interface Module...........
Old 06-15-2015, 11:24 AM
Atl_monte's Avatar
Where are these modules located on the car?
Old 06-15-2015, 04:12 PM
TipsyMcStagger's Avatar
2004 GTO = LS1.
2005-2006 GTO = LS2.
Look here (#7 & #31-#33)
Tipsy
Quick Reply: 04 GTO Swap Questions gauges?
