224/224 ls1 cam
This is the newbie area. This is where the new guys come for advice. Yes, there is a search function, but that doesn't always render results for a person's opinion.
Go here and read the two stickies. They will give you a lot of info. https://ls1tech.com/forums/generatio...rnal-engine-5/
Also, call TSP and tell them how your car is currently set up and what you WANT to do/what you WANT to get out of the motor. You can run the 224 and 228 without doing other work (though for best results you need to). However, once you dip into the 23X+ ranges you will need exhaust, converter (if A4), gears (new gears will differ for M6 & A4), tune...
Do lots and lots of reading. TSP and Tick will treat you right if you take the time to contact them.
