wire swap questions
wire swap questions
Hey guys. thanks for the help first off. love this site even if i dont frequent it much..
right now i have a blue red ecu and a blue green harness. trying to get the harness to work with the ecu so im matching wires using lt1swap.coms resource.
the following wires, im not sure if i actually need for my car and am looking for some input.
i am using a muncie m21 transmission.
do i need the clutch and neutral switches to start the car?
i will probably wire in the iac stuff. but can you guys help me fill in the blanks on this stuff?
BLUE
32 GRY 48 CPP Switch Signal (clutch switch)
34 ORN/BLK 434 Neutral Safety Switch Signal
RED
4 PNK/BLK 429 Air Injection Reaction Solenoid Relay - Coil - Control
30 DK BLU 229 Fuel Enable Control
44 WHT 1652 Reverse Lock Out Solenoid Control (MANUAL TRANS T56 ONLY)
53 GRA/BLK 1687 Ignition Retard Signal
76 LT GRN/WHT 1749 IAC Coil B High Control
77 LT GRN/BLK 444 IAC Coil B Low Control
78 LT BLU/BLK 1748 IAC Coil A Low Control
79 LT BLU/WHT 1747 IAC Coil A High Control
BLUE
RED
