Longtube ground clearance 1998 WS6 Trans Am?
I was told by my exhaust guy that I should "get shorty headers" because longtubes would scrape on the ground a lot. I really don't want shorty headers. I went there to ask if he would delete the cat with a pipe, and he said he can't unless we do something about the one on the manifold... which is when I told him I was going to get longtube eventually and he told me it was a really bad idea.
Shorty sounds like a waste of money, especially since I plan on getting a FAST 90mm and such on the intake side. I don't want to restrict my exhaust, and I want LOUD!
That is definitely not the case unless your car has been lowered a lot. Even then you just need to pay attention to your surroundings and take your time going over things like speed bumps. In my opinion the gains with a shorty header are not worth the cost or labor involved. Go long-tubes or leave the factory manifolds on the car.
__________________
Aaron @ Scoggin Dickey Parts Center
Email:Aaron387@sdparts.com
Phone: 1-800-456-0211 Ext: 324
That's what I thought. Thank you. Maybe I should find a new exhaust shop... (they've done great work in the past though. I just don't like being told what I want to do on my own car.)
Yes I would recommend long-tubes. That is one of the first mods most people perform on these cars.
__________________
I have Texas Speed 1 3/4 longtubes with a custom 3inch y, flowmaster merge collector and highflow spiral cats and I never scrape over anything. My 98 Trans Am is on stock spring and koni yellows. I scraped once going over a large speed bump with a passenger in the car. Go longtubes and never look back
THANK YOU. Is it more difficult to install? I can't for the life of me figure out why he wouldn't want my money to install the pipes I want? It sucks, because there aren't a lot of exhaust shops around here.
Oh, well. Either he'll install the longtubes and delete the cat, or I'll find another shop that will. I don't want to settle with this car just because some guy is lazy or misinformed.
After I'll just get a Frost Tune or something to get rid of the SES light (and get better timing while I'm at it.)
just install them yourself, it may seem daunting if you arnt that familiar with automotive work but trust me its easy, just time consuming. Ive done 2 LT installs and the first was car on a lift ( much easier) and second was just last month with car in my garage, biggest thing was getting it high enough. I drove car on rhino ramps and jacked it up further from when it was time to slide the new headers in. A friend is highly recommended otherwise youll have to do what I did and be creative when your trying to slide the pipes in from the bottom and grab them from the top to hold them in place and keep the gasket aligned while trying to thread a bolt in all at the same time lol. Its not hard just take your time and walk away if you get frustrated.
The only thing I can see shorty headers being better install-wise is you probably wont have to remove the steering linkage and you wouldn't have to get the car as high to slide them in. Neither of these two things are hard to do however and the HP and TQ benefit from LT's far outweighs shorties. Some brands of LT fit so well you don't have to do anything but raise the car up and slide them in, My BBK's were one such brand.
https://www.summitracing.com/parts/b...model/firebird
So with that part I don't need to buy any other hardware? I can just purchase these and have them installed?
Long tubes hanging too low was a problem on 60s and 70s cars, partly because they had to clear big *** oil filters, and probably also because a low ride height wasn't a thing back then. You should see how low the headers on my 79 TA hang to clear the oil filter.
My '01 TA has no problems. You can see they are tucked up nice and tight. The y pipe on the other hand hangs kinda low, but that's a problem even with the stock one. My car is on BMR springs, so it's lower than stock. I haven't had any issues scraping the y pipe yet, but I'm careful. If it ever gets smashed I'll build an oval one.
Attachment 720838
Attachment 720838
A lot of shops don't like installing headers because doing so can be a pain in the ***. Grumpy **** just may not want to because he doesn't like to or because he's old school and is thinking about it being 1981 still.
Buy these and the corresponding y-pipe, you'll be happy.
http://www.speed-engineering.com/sho...e-version.html
Corresponding y-pipe that will bolt right up to your factory exhaust. As you know, get a tune that will turn off your rear O2 sensors and you're good to go.
http://www.speed-engineering.com/sho...ad-y-pipe.html
Here is a thread on them. You want the 1 7/8 race version that is discussed later on in the thread.
https://ls1tech.com/forums/generatio...available.html
