NEED help Please ... Headlight problem
Me and my friends were working on my car yesterday. Then when I left my house and turned the headlights on, the lights actually turned on but they did not pop up (TRANS AM pop-up headlights). They did not even make a noise ... just stayed in their housing. It can't be the motor because it would either grind or only go up halfway.
Is it possible some wire accidentally got disconnected ? If so ... can someone point me in the right direction ?
well....you might want to check the weatherpack connector that goes to the headlight motor. i had the same problem last year, light would come on, but wouldn't pop up. turned out there was corrosion inside the connector. good luck.
had the same problem last week thought it was the motor but turns out it was just in a dead spot. i messed the manual remote thingy(behind the headlight) and now it works fine. i have also heard of the connectors failing or disconnecting.
