!air guide
!air guide
I hate to ask this question because i know its here i have seen it b4 but i cant find it now. Can someone give me the thread or a site that shows all the parts to remove. I think i have all them but want to make sure.
All there is to the AIR system are the connections to the headers/manifolds, the rubber tubes than connect to them then run across the back of the engine bay and up the driver's side fender, and the pump itself that you will find behind the driver's side headlight when you follow the tubes down there.
ok, i did get everything. Whats the box beside where the compressor was tho? I found the the link earlier in the exhuast guide when i was reading about the flowtech install. I knew it was somewhere in jrp's stuff but i couldnt find it. then i run across it on accident. thanks
