How many Hp?
How many Hp?
I have camaro 99 A4 with 3.42 and vortech the small one only 6psi. Slp longtube, Slp dual, 80mm throttlebody, slp 85mm maf. i have also subframe, now shocks and springs. .
I have run 8.699 at 1/8mil and 2.100 60/foot.
Is it normal?
How many hp can i have?
And whats next thing to change?
//Ahlis
Is it normal?
//Ahlis
u should rn better then that 1/8 my buddys as a4 273 with loudmouth cat back lid filter an slp ram air kit an 160 thermo an tuneing an he runs 8.6 flat, not sure how many horse u got but i would think it would be quicker, but who am i to say
Is it normal?
//Ahlis
Is it normal?
//Ahlis
Your times compared to your power sucks because you have not touched the drivetrain. You could have spent a LOT less on three things, and would be kicking your own *** right now, at a lot cheaper
-A bigger stall
-Tranny cooler
-Stickier tires (probably drag radials for now)
Honestly if it was me, I would sell the blower for a converter + cash
Horsepower and torque do not make you go fast. Horsepower, torque, and putting it to the ground makes you go fast. Keep that in mind, you need a LOT of work on your car in terms of drivetrain and chasis/suspension to make that power you have worth anything. But in time, you will be just fine
-A bigger stall
-Tranny cooler
I have not tune the car. The only tune is the one i got with the vortech. I have new Fuelsystem. 38lbs injektors and a new fuel pump. And i have http://www.bfgoodrichtires.com/bfgap...dragradial.jsp
It was on the street not on the track i ran 8.699.
Man you should be running way better than that. I would suggest the tune, because that seems like part of the problem. and the other part would be you. If you learn to drive your car your times will greatly improve...Just remember practice makes perfect, I sucked huge ones when first went to the track, and I still do. We all have room for improvement. Get the tune.
Fry
Fry
