I need some help.. two codes and pinging
1 Post
My car was in the shop for about 50 days...
I did the following mods.
Walbro 340
Swapped out TR230 for TR224 114 LSA
ASP Pulley install
!Wire
The car had about a half tank of gas this entire time.
Now.. The car has a terrible miss and horrible ping on take off.
Scanner pulled the following codes:
P0200 --- Injector Circuit
P1637 --- Generator L Circuit or something like that
I don't understand the P1637 code, but can the P0200 be caused my contaminated gas?
Walbro 340
ASP Pulley install
!Wire
The PCM is is detecting the wrong voltage for both of these codes - one from the alternator L terminal, the other from an injector. Check your !wire job, that will no doubt be your problem.
