JRP's FAQ For Commonly Asked Questions
Old 09-06-2004, 01:48 AM
jrp
SN95 Director
jrp's Avatar
Alloy Block
Aluminum blocks, or "cylinder cases" as engineers say, are becoming common for production engines. Why? fuel economy and exhaust emissions regulation have forced vehicle weight reduction and aluminum blocks weigh less.
Aluminum has downsides. For a given chunk of metal, its strength-per-mass is less than that of cast iron. With liquid-cooled, aluminum block engines, corrosion and porosity are durability concerns.
GM's first attempt at a high-volume, aluminum V8, a 4.1L pushrod engine in Cadillacs in the early-'80s, had many problems. Stripped head bolt-hole threads are so common that, today, many dealers keep thread repair kits in stock. Engine failures due to coolant-contaminated oil are, also, common.
It's taken years of work and not just a few angry customers, but GM has developed aluminum block reliability and durability to where its comparable to iron engines. For its part, the General improved its aluminum engines such that by the late-'80s/early-'90s, later versions of the pushrod Caddy along with the DOHC engines, LT5 and premium V8 (the "Northstar" 4.9L and the Olds "Aurora" 4.0L), proved excellent designs. Problems of the type that plagued the old 4.1 are unheard of with LT5s and Northstars.
By the mid-'90s GM was ready to try another aluminum, pushrod engine. One of the first challenges was to design the case. John Juriga told us, "Overhead cam engines are simple from a block standpoint. (The LS1) made for a complicated block design. The deep skirt, six-bolt bearing caps, deep-threaded head bolt holes, camshaft and tappet locations and other features made it challenging to engineer."
If packaging wasn't problematic enough, due to aluminum's lower strength-per-mass and higher coefficient of expansion, dealing with block distortion, noise and vibration gave design engineers fits. Burning fuel generates the torque that makes a car go. It also makes heat and stress which cause an engine to distort. This distortion of a few thousandths of an inch might seem trivial; however, it causes increased friction, cylinder bore distortion and degraded piston ring seal, all of which negatively impact fuel economy, exhaust emissions, durability and, of course, performance.
If you could measure a running engine in real-time, you would note that the block "quivers" like a big tuning fork as a result of stress to the block by the engine’s power impulses. This makes for noise and vibration, two more customer satisfaction issues.
Considerable design resources went into making the structure of the LS1 case both lighter and more rigid than that of the iron block engine it is replacing. Examples are: 1) many, external, stiffening ribs, 2) six-bolt, steel, main bearing caps and 3) the "skirt" that extends below the crankshaft centerline. These features make an extremely rigid case. Chevrolet refused to quantify this rigidity, but we suspect that it is significant. The pay-off is less noise and vibration, better fuel economy, reduced emissions, improved durability and higher performance.
"Once we had the design," Juriga continued, "there were casting and manufacturing issues that had to be resolved. First, what casting process to use. We went with a process that was relatively conventional in that it wasn't lost-foam or die-cast."
The LS1 block is made of 319 aluminum heat-treated to the T5 standard by the Montupet Corporation of Ontario, Canada. It is cast using the semi-permanent mold technique which Juriga described as "....a cross between die-casting and sand-casting." The case weighs 107 lb. Compared to the Gen II's 160 lb. block, that’s a significant weight saving.
The engine uses centrifugally-cast, gray-iron liners. The liners to be quite thin, but very strong due to centrifugal force increasing the density of the iron during casting. The sleeves are, then, cast into the aluminum block at the foundry. When asked in June of ’96 about these sleeves' tolerance of overbore during rebuilds, Juriga said that a thickness figure was unavailable and that, to date, GMPT had not addressed the service overbore issue. In a second interview, in March of 1997, John Juriga told me that the LS1 engines for MY97 and 98 will tolerate only about a .005-in. overbore which really amounts to just a clean-up hone. In 1999, the sleeves will be revised such that service overbore of .015-.020 is possible without compromising durability.
The liners are finished with a bore size of 99 millimeters (3.8976 -in.). That, with a stroke of 92 mm (3.6620-in), makes the LS1's displacement 5.665 liters or 345.69 cubic inches. Obviously, it won't fly with the Chevrolet marketing folks if, upon opening a C5's hood, people holler, "Hey, Vern! I got me one of these new, three hundert 'n' forty-six inch motors, here." so Chevy wants you to call it a "350" or a 5.7L engine.
John Juriga on working the bugs out of the manufacturing process: "Getting prototypes made without porosity, without cracks and on time was the next difficulty. To make a producible component–if I look back–was a steep learning curve for us. It was a challenge. It took us a while to get to where we could produce castings for our prototype builds in quantities that we needed."
At that time I also learned about the LS1 development via a good source on the C5 team. "We had problems with leaks due to sealing and porosity," I was told, "Both coolant in the oil and oil in the coolant. Another problem was getting engines. Any new engine program is going to have failures. Powertrain was working to solve them but there were times where vehicle development slowed because there were not enough engines. We even tried to fit LT4s in some C5s so we could push ahead with testing not related to powertrain, but the LS1 is shorter and the steering rack had been relocated rearward, so an LT4 just wouldn't fit."
Getting the manufacturing technology of the Gen III’s aluminum block right proved a daunting task that took a couple of years. Clearly, people at GMPD working to make the LS1 reliable and durable put in a ton of overtime and had to make some tough choices. One of those had GM discontinuing its relationship with the initial block supplier, Alcoa. Some of Alcoa’s manufacturing process were based on aerospace techniques. In this case, the attempted application of aerospace technology to automobiles was unsuccessful. Alcoa’s failure to perform drove the GM decision to transfer the casting to Montupet. Other hard decisions came later upon discovery of a problem with the LS1’s oiling system which is covered later in this article.
While these problems were traumatic, they are an expected part of the high-stakes business that is bringing a new engine to production. GM designs, develops, tests, then develops some more based on that testing. Eventually, this process results in a Corvette powerplant that is reliable, durable, drivable and capable of best-in-class performance. If my road test experience in a pilot cars along with the experiences of other magazine test drivers is any measure, GM has a home run in this engine
jrp is offline
Old 09-06-2004, 01:49 AM
jrp
SN95 Director
jrp's Avatar
Plastic Intake
How 'bout that plastic intake manifold, eh? Okay, we'll use the marketing buzz word "composite" once, but we common folk find the stuff of which that intake is made closer to plastic than anything else. Specifically, it’s a Dupont material called "Nylon 66" that is a mixture of a Nylon and glass fiber reinforcement.
Plastic manifolds are easier to manufacture, weigh less, run cooler and better lend themselves to intricate designs. We wonder how long it will take C5 design chief, John Cafaro, to discover plastics can be dyed to get stuff like fluorescent-pink intakes? Ok. Just kidding. Ah....but don't get any ideas, Cafaro.
The first question about a plastic intake is, "Do they, like...melt when the engine overheats?" Well, if overheating means setting your C5 on fire; then the intake will probably melt; however, this manifold will withstand the heat of operating temperature, even that of an engine stuck in Death Valley in mid-August with a coolant overtemp situation.
This intake manifold uses some cleaver packaging. The plenum is beneath the runners allowing the runners to be long, but also to curl smoothly from their junction at the plenum, up and over to each intake port in the heads. The smooth curves, also, enhance airflow. The plenum occupies space in the valley, making the engine as short as possible. The intake is well-integrated with the intake ports, because, in the early stages, the same person had design responsibility for both.
Look closely at the throttle body on the front of the intake manifold and you’ll see a major innovation. Instead of a throttle bell crank there is an electric throttle control (ETC). LS1 will be the first throttle-by-wire application in a GM car. The connection between your right foot and a C5 will be via a wiring harness. Throttle-by-wire has been used in aircraft for many years and on a GM light-truck, diesel application since 1995, but C5 will be its first performance car application outside of motorsports.
The LS1’s sequential electronic port fuel injection (SFI), is similar to what has been used since 1994. Each cylinder has its own ACDelco Multech injector to meter fuel. A mass air flow (MAF) sensor, meters the air. The injectors are controlled by the PCM. It sets the fuel delivery schedule by applying data, such as crankshaft position, mass and temperature of intake air, engine speed, coolant temperature and a few other parameters, to fuel "look-up" tables in the PCM software or "calibration." Based on those look-up tables, each cylinder’s injector is "pulsed" in the engine’s firing sequence such that a precisely metered amount of fuel is shot down the intake port just before the valve opens.
Under many driving conditions, the PCM uses a "feedback loop" to trim fuel delivery to optimum levels. Free oxygen in the exhaust is an accurate measure of fuel mixture. The feedback comes from oxygen sensors (O2S) screwed into the exhaust manifolds. They measure the oxygen content and send that information to the PCM. When the engine runs in this "closed loop," combustion is optimized for best performance, exhaust emissions and drivability.
One interesting aspect where LS1 departs from the Small-Block is that the whole induction system, intake manifold, throttle body, injectors, fuel rails and wiring, is assembled by an outside supplier, shipped to the engine plant as one piece and simply bolted in place.
LS1 uses a tuned, intake port length as did the L98 of 1985-'91; however, LS1's 15-in. runner length is tuned for top-end power whereas L98s 21-in. runner was tuned for mid-range torque.
The Rest of the Basic Engine Story
The crankshaft material is cast, nodular iron, the same used for Gen II and many Gen I cranks. It is noticeably shorter than that of a Small-Block and the main bearing size is larger than that of all except the old 400. The rod bearing journals are the Small-Block "large journal" size. In fact, the only part in the whole darn engine that carried over from the Small-Block are the rod bearings. For improved strength, the crank uses the rolled-fillet journals introduced with LT4. The crank weighs a bit more because of the larger main bearing journals and an ignition trigger wheel that is part of the casting. In another departure from the Small-Block, to reduce the effect of crankshaft expansion on alignment of internal engine parts and external accessories; the crankshaft thrust is taken by the center main bearing rather than the rear unit.
The LS1 uses a sintered, forged, PF1159M steel connecting rod. Also called "powdered metal" or "PM," this technology was introduced in Corvettes for MY96. The basic, Small-Block rod currently in the GM Performance Parts catalog is also PM.
To make a sintered rod, a mold is filled with steel powder which is "briquetted" or compressed under extremely high pressure. Then, the rod is "sintered" which heats the metal just to its softening point causing the steel molecules bond and making a dense, very strong part. Next, the rod is put through a conventional forging process. Lastly, it is shotpeened. The combination of these manufacturing techniques results in a rod with "net shape," which requires no machining for profile or balance and is more consistent in mass than rods of traditional manufacture.
The LS1 rod is also known as a "cracked rod" because the big-end is fracture split. During the finishing process, to split the big-end; a stress riser is cut into its inside diameter. The rod is stressed such that it fractures at that riser. The jagged surface left on both pieces precisely locates and locks the rod cap in place once the rod is assembled. For simple assembly and mass reduction, the LS1 rods use a 9 mm. capscrew rather than a rod bolt and nut to hold the big-end together.
Rod length is 6.1 in., .400-in more than the LT1/4 rod. The extra rod length reduces rod angularity and piston speed which decreases friction and noise and increases durability. LS1 rods have no balance pads making for less overall mass and allowing the engine to rev quicker. Undoubtedly you're asking, "Hey, wadaya mean 'no balance pads.'? How do they balance the rods, then?"
Well, they don't.
Small-Block rods were held to a weight tolerance of ±5 grams, per end, after balancing. The LS1's PM rods are manufactured to a tolerance of ±3 grams for the small end and ±4g for the big end without machining for balance. Such are the advantages of a net shape.
How good is this connecting rod? Many stock rod Small-Blocks, after lengthy time in severe duty, will display fretting corrosion of the inside diameter of the big end. This is due to the big end flexing a tiny bit under the bearing shell. The LS1 rod, under similar operating conditions, shows virtually no fretting. Bottom line: The LS1 rod is the strongest connecting rod ever used in a GM, production, mid-displacement V8.
The new engine has of cast aluminum pistons. Their compression height is 34mm and they weigh 434 grams each. Unlike production Small-Block pistons, they have no steel reinforcement strut. The old engine needed that feature to control piston expansion because the manufacturing process controls used previously and bore distortion due to the old engine's having head bolts threaded into the block decks, made for wide variation in bore sizes. To keep piston-to-bore clearance such that acceptable durability would come even with the smallest, expected bore size; piston expansion had to be restricted and that was done with the steel reinforcement.
With the Gen III engine family, process controls at the block machining stage are tighter and there is no bore distortion due to head bolts because their threads are very deep in the block. With bore variation significantly reduced, piston expansion control is not an issue, so the steel strut was eliminated making for a lighter piston that is less costly to manufacture.
The biggest visual differences between pistons for the new engine and those for LT1/4s are 1) LS1 units have no valve reliefs, 2) they have 6mm. less compression height which allowed the longer connecting rod and 3) the top ring was moved up 1.5mm.
There is a ton of technology in piston and rings aimed at reducing friction. The rings use the same basic materials as before but the design is different. The LS1 top and second rings have 1.5mm faces vs. the 2.0mm rings used in LT1/4. The tension of all rings have been reduced by about 30%. Reduction in ring face widths and tension would never have proven reliable from a cylinder sealing and oil consumption standpoint, if process control improvements did not result in reduced bore variation and improved consistency in individual bore diameters.
The LS1's pistons are lighter than a LT1/4 piston. A bore size 2.5mm smaller, 6mm less compression height and the lack of a steel strut make this possible. Improvements in LS1 rods and pistons have reduced the weight of each rod/piston assembly by 120 grams compared to the same LT4 pieces. That is a significant decrease that guarantees the engine will rev quicker (and it does!!) and be more durable at high engine speeds
jrp is offline
Old 09-06-2004, 01:50 AM
jrp
SN95 Director
jrp's Avatar
Oiling System Snag
After the aluminum block and plastic intake, the most noticeable part on an LS1 is the oil pan. Sources involved in C5 testing call the intricate aluminum casting a "bat wing" pan. It's part of the lower engine structure and contributes to overall cylinder case rigidity. Gen III continues the recent tradition of little oil filters but the filter mounts on the rear of the oil pan rather than the block. As with LT1/4s, no oil cooler is available and the factory fill will be synthetic oil. Testing shows the oil temperature range to be similar to what we see in Gen II Small-Blocks.
The new engine uses a gerotor oil pump that is driven off the front of the crankshaft. Gerotor pumps are used in many recent engine designs. They are less complex, less costly to make and require less power to pump a given volume at a given pressure.
Oil distribution has changed significantly from that of the Small-Block because of: 1) the front pump, rear filter arrangement (the old engine had both at the back) and 2) the LS1's main oil galley feeding the main bearings and the camshaft simultaneously (the Small-Block main galley fed the cam bearings first, then the mains). John Juriga tells us that the Gen I/II oiling system was very reliable and that the change in oil routing in the new engine came mainly out of manufacturing concerns.
One of the unexpected challenges of the C5 vehicle development program centered around the LS1’s control of oil drainback and oil supply during high rpm operation with the vehicle sustaining maximum lateral acceleration (max. lat.), In February of '95, during maximum lateral acceleration testing on the skid pad at the GM Desert Proving Ground, problems with engine oiling began to crop up that were unrelated to earlier difficulty with cylinder case porosity. There may have been half-a-dozen or more engine failures due to this new problem. There was much head-scratching about why C5s were popping motors as if it were happy hour at a Winston Cup qualifying day.
By the end of the first quarter of 1995, it was established that the trouble was caused by two problems: 1) crankcase windage. The LS1's deep-skirted block, six-bolt main bearing caps and a higher oil level that goes with a shallower oil pan effectively divided the crankcase into four distinct "bays." Early blocks did not allow efficient transfer of air between bays as the pistons moved in their bores. At high rpm, the violent turbulence caused by this absence of pressure relief aerated the oil. This problem also restricted oil drain-back from the upper end of the engine. The combination of oil foaming and poor drainback degraded the oil supply. 2) lateral acceleration. At "max. lat.", oil level in the pan could reach a 45 degree angle from horizontal. Combine these two problems, sustain them for several seconds and, often, the oil pickup would suck air and oil pressure would be lost. No pressure meant certain engine bearing failure and that brought premature end to the testing excitement.
Throughout the summer and fall of 1995, the lights burned late in Powertrain Headquarters at GM's "Tech Center" in Warren Michigan. In the end, three solutions were found. First, to address the oil foaming and poor drain-back, the structure of the Gen III case was modified to allow pressure transfer between bays. Second, to improve oil supply at max. lat., a complex oil pan design incorporating sump extensions (the bat wings), extensive baffling and trap doors was devised. Third, to help with with the first two problems, the oil capacity was increased from four to six quarts.
Interestingly, the LS1 oil pan is reminiscent of the wet sump, road race oil pans used by amateur racers before SCCA allowed dry sump oiling systems in the mid-1970s. In fact, a dry sump oil system for LS1 was studied, but never went past the paper stage due to cost and concerns about low oil temperature during warm-up.
Last June, Project Manger Juriga assured us that the critical problem had been solved; however, we learned afterwards that the anomaly will still occur in extreme situations of high-rpm, sustained, max. lat. operation. An example might be abusive skid pad testing done by some of the less-experienced automotive media.
We also learned that, in an unusual solution, that in mid-’96 GM Powertrain wrote the LS1 PCM calibration such that, if high rpm and high lateral acceleration are sustained for a substantial length of time; the electronic throttle control (ECT) will reduce throttle opening to slow the car. In a follow-up interview in March of 1997 for the WWW versions of this story, John Juriga confirmed that the ’97 Vette’s PCM calibration is written that way.
We know C5 was tested extensively at the Road Atlanta, Road America and Grattan, Michigan road race tracks, so we believe that, in most real-world driving situations you’d see in a Corvette, including road racing; the LS1 oiling system is dead-nuts-reliable. However, if a LS1 is run on a skid pad at high-rpm and max. lat. for 45 or more seconds, we suspect that ECT will reduce the throttle opening.
jrp is offline
Old 09-06-2004, 01:54 AM
jrp
SN95 Director
jrp's Avatar
Cylinder Head Wizardry
From a performance standpoint, cylinder heads are the most significant feature of LS1. An airflow genius at GM Powertrain, named Ron Sperry, oversaw the design. To hardcores seriously into Chevrolet heads, Sperry is a folk hero. Fifteen years ago, working for the legendary Vince Piggins in the Chevrolet Special products group, he contributed to the original Chevy "Bow-Tie" heads. Evidence that success in motorsports transfers to production is that the L98 aluminum head, introduced on Corvettes a decade ago, was derived from philosophies used in those late-’70s/early-’80s race heads.
Later, Ron Sperry perfected his craft working for Herb Fishel at the Chevrolet Raceshop. He was responsible for two of Raceshop's landmark designs of the mid-’80s: the raised-runner, NASCAR Small-Block head and the symmetrical-port, big-block, Pro Stock head.
Ron Sperry joined the V8 Group at GM Powertrain as the Cylinder Head Release Engineer in the fall of 1987. Need more proof that racing improves the breed? His first task was developing the production, Gen II head that debuted on the 1992 LT1. A source close to the Raceshop told us simply, "He (Sperry) showed them (GM Powertrain) how to make power with it." Sperry's early work on Gen III resulted in the LT4 head. He was able to tweak just a bit more out of a mature design such that LT4 is the high-water mark for production, Small-Block V8 cylinder heads.
Ron saw the LS1 project as a great challenge and a wonderful opportunity in that he was able to develop a cylinder head for an all-new, production high-performance V8 engine with few of the performance constraints he had worked under in the past.
All previous, production Chevrolet V8 heads have two distinct intake and exhaust port designs. A unique feature of the LS1 head is what GM calls "replicated" ports. Each intake port is exactly same and each exhaust port is exactly the same. This eliminates combustion inconsistencies between cylinders due to variance in port flow quality and quantity.
The heads are sand cast of 356 aluminum, heat-treated to the T6 specification. Engineers use the term "valve angle" to describe the angle between cylinder bore centerline and the valve stem centerlines. It is probably the key geometrical relationship in a V8 head because it influences combustion chamber shape and size, spark plug placement, valve diameters and port design. With V-type engines, the less valve angle; the better. The LS1 angle is 15,° three less than the best of the Raceshop's Winston Cup heads and significantly below the production Small-Block’s 23°.
The LS1 intake port volume is 200 cc. which is a bit of a misnomer because of some of that volume is used for injector spray space; nevertheless, intake volume is generous. The exhaust port volume is 70 cc. The valve seat angles are 30°, 45° and 60°. The chamber roof around the valves blends smoothly with the seat’s top angle. The valves are stainless steel. The intake valve size is 2.00 in. and the exhausts are 1.55-in. with both having smaller, 8mm. valve stems. The valve face angles are 30°, 46° and 60°. The valve guides are pressed-in, sintered-iron units impregnated with material that enhances lubrication. Chamber displacement is 67.3 cc which makes for a compression ratio of 10.2:1.
The most important aspect of this head from a performance standpoint is an intake port that offers the charge air a straight shot down to the intake valve. In that respect, the difference between the intake port in the best of the old (LT4) and the first of the new (LS1) is nothing short of dramatic. We were very lucky to get to talk with the cylinder head ace himself, Ron Sperry and he said, about the design philosophy he and his team of engineers used for the intake ports, "We worked hard to make sure we had all eight cylinders as close to being identical, from a geometry standpoint, as we could. Each port is a continuous, runner-to-valve configuration. We don’t have the air turning right or left to any significant degree. There is a relatively large runner opening and it tapers down so that as (the charge air) gains speed, it’s also gaining directional stability such that the air is moving towards the valve in a very directed manner. We get the air and fuel into the cylinder with the same level of energy from bank-to-bank and port-to-port. "
Sperry added that a big enabler for the port design was packaging. By using four head bolts around each cylinder rather than the Small-Block's five, there was more room for the ports. Additionally pushrod holes, head bolt bosses and rocker arm mounting bosses were placed such that they impacted the intake ports as little as possible.
Another important feature of the LS1 intake port is it has better "injector targeting" than any Small-Block head. Injector targeting is important to idle quality and exhaust emissions. Ideally, port-injected engines should have injectors squirting a stream of fuel straight down the port, directly on the back of the hot intake valve. The temperature helps vaporize the fuel and the turbulence of the charge blowing down the port and around the valve does the rest. With the Small-Block, a straight shot at the valve was not as effective because the line running from the injector to the valve was nowhere near parallel to the port centerline. Ron Sperry: "Each port's fuel injector is targeted on the valve. We established a (port) centerline in space. The port runs back from the valve to the injector in a manner that is more linear with the injector target line."
A good cylinder head design gets the exhaust out as freely as it lets the charge in. Ron explained LS1 exhaust port philosophy, "The 15-degree angle goes a long way to fixing most of the problems we had (with the Small-Block exhaust port). The chamber is a very open design. Chamber volume is bigger than its predecessor, 54cc in the LT4 and 67cc with this engine. The 15-degree angle removes many of the short turn radius (where the port floor transitions to the valve seat) problems.
"All the surfaces are friendly in approaching the valve seat area. The valve is shrouded a bit on the bore side, but that’s about the only area there’s any restriction to getting exhaust out of the engine. We did employ the venturi-type seat that we put in the LT4 but it doesn’t have to be as drastic. The exhaust ports have some really good (flow) numbers right out of the box. They are as good as some of of the exhausts we’ve seen with modified, Bow-Tie stuff."
If you retain only one part of this discussion of the LS1 head, remember that most of this cylinder head technology goes towards one goal: increasing volumetric efficiency. If you pack more air into the cylinders, the engine makes more power. The LS1’s much better intake and exhaust port designs allow better volumetric efficiency at all engine speeds. The payoff is higher performance.
LS1's head gasket sealing is better than that of the Small-Block. The long head bolts go 88mm down into the block and have very long threads of a unique size and pitch designed for high load. They screw into threads in the case’s main web areas. The idea is to pull the sleeves and the immediate surrounding area of the decks tight against the head by exerting force at the bottom of the sleeves. An additional feature is the bolts’ length. A fastener exerts the most force when its stretched slightly and the long bolts allow a lot of material for stretching.
One final, interesting aspect of the LS1 head and deck design is that it has a negative deck-height figure. One of GMPD’s goals in combustion control was to decrease "crevice volume" which is, loosely speaking, the "squish" volume between the flat, non-chambered, part of the head exposed to the bore, plus the volume between the piston and bore above the top ring. At top dead-center, an LS1 piston top is actually 0.2mm (.008-in.) higher than the block deck and protrudes into the space surrounded by the head gasket. A typical rebuild procedure is to machine or "deck" the block to correct misalignment or lack of flatness. Once the first LS1’s need overhauls, engine rebuilder will have a learning curve with figuring out how to deck an LS1 case and preserve piston-to-head clearance.
Pushrods and Why
By now, you’ve probably exclaimed several times, "Heck, guys, your ah....‘new’ engine has got friggin’ pushrods. How in blazes can ya call that ‘revolutionary technology’?"
For ultimate performance, it’s tough to beat DOHC and 32-valves; nevertheless, GM Powertrain decided to use pushrod-operated valve gear for the LS1. Why? To quote John Juriga, "The LS1 is the only engine in the Corvette for 1997. We think a base engine at 345 net horsepower is plenty of power. If that can be done with one cam, 16 pushrods and two valves in each hole; we can live with that."
There has to more to this issue than that, and we intended to ask Ed Koerner, Gen III Chief Engineer, to comment further. Unfortunately, Chevrolet denied our request for an interview with him. We later sent Chevrolet a question about the valve issue to forward to Mr. Koerner, but that went unanswered as well, so heck; we had to guess.
First, the obvious: money. It costs less to build a pushrod engine. There is one cam, not four; one cam drive chain, not three, 16 valves and associated parts, not 32 and a less complex head design. To have a reasonably flat torque curve, the DOHC LT5 needed a complicated, expensive, computer-controlled, secondary throttle system. The LS1’s advanced, two-valve head eliminates the need for that. Lastly, the C5 version of the Gen III is derived from a cast iron passenger car/light-truck powerplant to be built in the tens of millions, so the cost of developing the LS1 can be distributed over a much larger sale of similar engines.
jrp is offline
Old 09-06-2004, 01:57 AM
jrp
SN95 Director
jrp's Avatar
Second and less obvious: attitude. It is unlikely General Motors will ever again see the brash thinking that spawned the LT5. Development costs were excessive, purchase price was high and sales numbers were too low. In 1992, GM was almost broke and at one point, literally, only days away from closing its doors. These were sobering thoughts to the high-level execs who wrote the checks and answered to stockholders. The aftermath, the downsized, "Dilbert Era" of the mid-90s, was traumatic for the General’s bad-boy, car-guys. LS1’s technology is cutting-edge, but it had to come from a different side of the blade than did LT5. This new engine’s existence was contingent on cost-effectiveness, as well as performance and that meant 16, pushrod-operated valves.
Want more? Well, how ’bout marketing? Gen III’s main, target market is going to be trucks. About 25,000 a year will go in Corvettes but hundreds of thousands a year will go in trucks. Many people don’t see overhead camshafts as a positive selling point for truck engines. Truckers want cheap, simple, reliable and durable powerplants and that means a single cam and pushrods. A final consideration may be packaging. The C5 engine compartment was not designed for the width a four-cam engine.
Our reaction to the LS1’s valve gear? Well, frankly, we don’t think any Corvette needs technology for its own sake. We have too much of that already. The LS1's superior cylinder head allows near-LT5-level performance right now with only two valves per cylinder. Like John Juriga, we can live with that. If you think the LS1 can’t touch the LT5; development engines are running on GM Powertrain dynos at the 400hp level with little modification. Will there be a "super-LS1" in the C5? Our fearless forecast is: yes, perhaps by 2000; however, you'll see a 400hp LS1 even sooner from Corvette tuners like Doug Rippie and John Lingenfelter.
Gearhead’s View of the Valvetrain
The LS1 camshaft is machined out of a steel billet and is rifle-drilled to reduce mass. A camshaft sensor, necessary on engines with SFI for the PCM to "know" where the engine is in the firing order, is just ahead of the rear bearing journal. Compared to LT4, the LS1 cam has larger bearing journals, all the lobes have bigger base circles and lift is less, especially the intakes. Going to the larger base circle and less lobe lift reduces valve train loadings because the acceleration rate is lower.
The new engine’s rpm limit is about the same as that of a LT4. That, along with the lower valve acceleration rate, allowed many valve train parts to have less mass which permitted use of lower tension valve springs and that lessens the impact as the valve hits the seat on closing. Valve train noise is reduced which, according to John Juriga, was a big goal of the Gen III program. Specific to Corvettes, maybe that is not all that great an idea. The Corvette Mystique partially grew out of mechanical lifter camshafts. Give us that’ 92 LT1 valve noise, thank you very much.
The valve lifters are the roller hydraulic variety and are the second of the two pieces that carry over from the Small-Block. The centerlines of the lifters, pushrods and the valve stems are parallel. The Small-Block had them at angles to each other. These angles caused side loading which accelerated valve guide and lifter bore wear and increased friction. The LS1’s "in-line" valve train reduces friction and allows some parts to be made smaller and lighter.
Bet ya saw those fancy roller rocker arms, too. Some Corvette owners are gun-shy of roller rockers because of the fiasco with not one, but two recalls during MY96 of a large number LT4s due to rocker arm failures caused by roller tip pins falling out. Ironically, the second recall affected all the cars of the first. Is that, like....a "re-recall"? Sorry, but we couldn't resist that. We know customers told not to drive their LT4s because of an initial shortage of recall repair parts saw little humor in that situation.
For those with such roller rocker "phobia"; LS1 is good therapy. Its rockers are investment cast steel rather than aluminum and the roller tip pins are held securely in place. The rocker arm ratio is 1.7:1 vs. the LT4’s 1.65:1 and other Small-Blocks’ 1.5:1. The higher mechanical advantage of the LS1 rocker amplifies the smaller lobe lift such that valve lifts for an LS1 are: .472-in. for intake and .479-in. for exhaust compared to the LT4’s .476/.479 lifts. Chevrolet refused to share additional valve timing data with us.
John Juriga’s last words on the LS1 camshaft were, "We didn’t go more aggressive on the cam, so at this point, the engine has a lot of potential. First time out, we could meet our target with a camshaft that is conservative."
This might indicate that there will be a lot that performance tuners will be able to do with this engine’s camshaft.
Cooling the Traditional Way
Remember 1992, when Chevy raved about the Gen II’s reverse-flow cooling? Well, reverse is, apparently, out. The new engine uses conventional pushrod V8 cooling. Coolant is pumped into the block, around the cylinders, up into the heads, then out to the radiator. The reason Gen II went reverse was that, to make the power Corvette Development wanted; it had to have a higher compression ratio (LT1, 10.2:1; LT4, 10.8:1). Higher compression made for detonation. The cooling system was revised to run the cylinder heads cooler as an antidetonant strategy, and to run the cylinder bores hotter for higher oil temperature and less friction. Clearly, reverse-flow cooling, the publicity darling of the Gen II engine, was really nothing more than a fix that allowed the limited cooling of the old Small-Block head to work with the higher compression necessary to reach the 300 horsepower level.
Air in the cooling system becomes problematic if it gets into the water passages surrounding the combustion chambers. This often causes localized boiling and that, in turn, allows hot spots to develop on chamber walls and they cause detonation. The problem with reverse flow is that with coolant flowing downward and air bubbles flowing upward; keeping air out of the Gen II cooling system was difficult.
Though the LS1 has a lower static compression ratio; its cylinder heads have improved combustion chamber design and intake ports that breathe better. Those features allow them to make more power. The clean-sheet-of-paper approach also allowed design of the cooling passages around the chambers to be more efficient such that the engine can put out more power than the Gen II but yet have coolant flow in the conventional direction to eliminate problems with aeration. With a better combustion chamber and water jacket design and improved antifriction technology in the block, pistons and rings; it made sense to go back to the normal-flow cooling system.
Like most engines of the last 20 years or so, the LS1 uses a 195 degree thermostat. Nominal coolant temperatures are similar to what we see in LT1/4 engines. The new engine will use "Dex-Cool" coolant introduced last year in many GM vehicles. Dex-Cool has entirely new anticorrosive chemistry that is longer lasting and more friendly to cooling system parts, especially seals.
jrp is offline
Old 09-06-2004, 01:58 AM
jrp
SN95 Director
jrp's Avatar
Ignition
Gen III’s ignition system is evolutionary. In 1990, with the LT5 engine, Chevrolet introduced a distributorless ignition system (DIS) to the Corvette. The next step is the LS1’s coil-per-cylinder idea.
The ignition hardware is mounted atop the valve covers. Each cylinder has its own coil and coil driver assembly and a short plug wire connects each a spark plug. The reasons for moving the coils to the covers are simple: 1) less spark energy is dissipated by short spark plug wires so more energy available at the plug, in fact, it increases nearly 100% and 2) shorter plug wires reduce radio frequency interference with on-board computers and the sound system.
The other big ignition story with Gen III is a different firing order. Gone is the time-honored 1-8-4-3-6-5-7-2 sequence. This new engine fires 1-8-7-2-6-5-4-3. The cylinders are numbered the same: left bank: 1-3-5-7 and right bank: 2-4-6-8. The reason for the new firing order is better idle stability and less vibration.
The rest of the ignition system is conventional. The ignition advance is controlled by the PCM based on manifold pressure, air temperature, engine speed, coolant temperature and a few other data. The PCM computes the optimum trigger point then sends a trigger impulse to the coil driver at the appropriate cylinder.
Detonation protection is similar to what’s been used in the past. There are two knock sensors (KS) working in a feedback system with the PCM. When a KS "hears" detonation, the PCM retards timing a set amount and for a set time, then waits for additional sensor input. If the detonation stops; timing is gradually reset to the value called for in the PCM calibration. If detonation continues, timing is retarded an additional amount.
Spark plugs are an AC, platinum-tipped plug of a type similar to that introduced in 1992 on the LT1.
Exhaust, emissions control and accessories
LS1 exhaust manifolds are double-walled and welded-up from hydro-formed, tubular stainless steel. The double-walls prevent heat loss between the head and catalytic convertors which is a big factor in how quickly the cats. start catalyzing the exhaust. Late cat. "light-off" is a significant contributor to exhaust emissions during cold starts and early warm-up. Unlike the LT1/4/5 engines, the LS1 cats. are not attached right at the exhaust manifold outlet. They are a bit farther downstream and because of that, it was necessary to add measures to reduce heat loss and preserve quick cat. light-off.
The rest of the LS1 emissions controls are similar to what has been used on Corvette since about 1990. There is an electric air injection reactor (AIR) pump that runs after start-up for a short length of time set by the PCM. Interestingly, the LS1 is the first Corvette engine since the early-;70s that can pass exhaust emissions standards with out an exhaust gas recirculation (EGR) system. LS1 has the second generation, on-board diagnostics (OBD-II) used, in part, since 1994, and, in entirety, starting in 1996. The LS1 PCM has more computing power than the ’94-’96 units which allows the new engine to be OBD-II-compliant in a more "seamless" manner. Additionally, it allows the C5 platform to meet more stringent emissions regulation due in the late-’90s and early-’00s.
OBD-II is one of those wonderful Federal mandates that’s raised the cost of cars but will have little practical impact on air quality. Nevertheless, it has satisfied the vote-getting needs of politicians who pander to the environmental lobby and it has driven some pretty amazing technology from car companies.
The biggest difference between so-called, "OBD-I", used on Corvette from the late-’80s to 1993, and OBD-II is that the current system requires the PCM to predict potential failures of emissions controls as well as notifying of failures that have already occurred. Two significant features enabling this prediction are catalyst monitoring and misfire detection.
The catalytic converter makes a large contribution to reducing emissions. OBD-II monitors cat. performance by taking oxygen readings from a second pair of oxygen sensors downstream of the cats. When the downstream readings begin to mimic the upstream readings, the PCM assumes cat. performance is starting to degrade and turns on the malfunction indicator light (MIL).
Misfire detection is the most complex engine management problem faced by the car companies in a decade. It demands a very fast, powerful and sophisticated processor in the PCM, very accurate crankshaft position data and some technically innovative software. The PCM reads very small and extremely rapid variation in crankshaft speed as the engine accelerates and decelerates in reaction to power impulses. Inconsistent variations in those accel. and decel. rates are indicative of engine misfire. Specific types and durations of misfire can be a sign of other emissions system problems and will turn on the MIL. The trick comes in accurately determining what’s misfire and what’s not. That has stumped some of the automobile industry’s biggest players, especially with manual transmission powertrains.
GM Powertrain Division leads the industry in diagnostics. Since full-OBD-II compliance became law (generally, with the 1996 model year) there have been cases of car companies discontinuing manual transmissions on some models due to failure to meet the misfire detection challenge. The most notable example occurred in 1996 when there was no manual version of Toyota’s flagship Supra Twin Turbo. It has also been rumored that the Mazda RX7 TT’s departure at the end of 1996 was also, in part, because of Mazda’s inability to address OBD-II. The 1997 Corvette has a manual transaxle available because GMPD has successfully answered the misfire detection challenge with the LS1.
Most of the accessories used on the LS1 we have seen before. LS1 uses a dependable, ACDelco, CS-series alternator. A geroter pump supplies steering power assist. The water pump, of course, is new as is the air conditioning compressor. As with several recent GM engine programs, most notably the Gen 1E for trucks; noise and vibration inherent in accessory mountings was carefully researched, then reduced by designing very rigid accessory mounts, quiet running accessories and an accessory drive that uses two serpentine belts. One drives the air conditioning compressor and the other drives the rest of the accessories.
In Closing
The various PR apparatus at Chevrolet, GM Powertrain and GM Midsize/Luxury Car Division would like everyone to think that Corvette development is as simple, quick and trouble-free as is bringing to market a new type of vegetable slicer, hair dryer or whiffle ball racquet.
Not even.
Development of an all-new engine is a monumental task requiring hundreds of individuals to work tens of thousands of man-hours. It is complex, costly and filled with surprises. It is a credit to the team at Powertrain that it addressed each challenge with effective solutions.
Well, this new medium-displacement V8 is quite an engine, don't you think?
LS1 generates 345hp at 5600 rpm and 350 lbs/ft. torque at 4400 rpm. Maximum engine speed is 6200 rpm. Compared to the LT4, it generates 15 more horses with peak power 200 rpm lower. It produces 10 more lb/ft. torque with peak torque 100 rpm lower. Chevrolet refused our request for a chart of LS1’s torque curve, but we believe it’s a bit flatter than that of the LT4. All this performance comes from a package weighing 66 pounds less and measuring half-an-inch shorter than a Gen II Small-Block. Some of us still compare today’s power ratings to the gross power figures of the 1960s. If that was still being used, LS1 would put out about 390-400hp. Most notable is that this engine is the first two-valve V8 to reach the one-net-horsepower-per-cubic-inch plateau. That is a monumental engineering achievement.
I recently received a very interesting insight to the power of the LS1. A high-level Corvette Development executive told me that he personally back-to-back tested both a stock, 1995 ZR-1 and a 1997 prototype. The ZR-1, with 60 more horsepower, was a mere second-a-lap faster than the C5. That says much about the ’97’s new engine, lighter weight and better handling.
Bottom line...the new LS1 is all Corvette and one hell of an engine.
jrp is offline
Old 09-06-2004, 06:43 PM
jrp
SN95 Director
jrp's Avatar
Engine Mechanical Specifications (LS1)
General Data
Engine Type V8
Displacement 5.7L-5665 cc 346 CID
Bore 99.0 mm 3.898 in
Stroke 92.0 mm 3.622 in
Compression Ratio 10.1:1
Firing Order 1-8-7-2-6-5-4-3
Spark Plug Type 41-931
Spark Plug Gap 1.524 mm 0.06 in
Lubrication System 5.678 Liters 6.0 Quarts
Oil Capacity (without Oil Filter Change) 6.0 Quarts 5.7 Liters
Oil Capacity (with Oil Filter Change) 6.5 Quarts 6.151 Liters
Oil Pressure (Minimum -- Hot) 41.4 kPa at 1,000 engine RPM 6.0 psig at 1,000 engine RPM
Oil Pressure (Minimum- Hot) engine RPM 124.11 kPa at 2,000 engine RPM 165.48 kPa at 4,000 engine RPM
engine RPM 18.0 psig at 2,000 engine RPM 24.0 psig at 4,000 engine RPM
Oil Type Mobil(E) 5W-30 Synthetic or Equivalent
Camshaft
Camshaft End Play 0.025-0.305 mm 0.001-0.012 in
Camshaft Journal Diameter 54.99-55.04 mm 2.164-2.166 in
Camshaft Journal Diameter Out-of-Round 0.025 mm 0.001 in
Camshaft Lobe Lift (Intake) 7.04 mm 0.277 in
Camshaft Lobe Lift (Exhaust) 7.13 mm 0.281 in
Camshaft Runout (Measured at the Intermediate Journals) 0.05 mm 0.002 in
Connecting Rod
Connecting Rod Bearing Bore Diameter 56.505-56.525 mm 2.224-2.225 in
Connecting Rod Bearing Bore Out-of-Round (Production) 0.004 mm 0.00015 in
Connecting Rod Bearing Bore Out-of-Round (Service Limit) 0.008 mm 0.0003 in
Connecting Rod Bearing Clearance (Production) 0.015-0.063 mm 0.0006-0.00248 in
Connecting Rod Bearing Clearance (Service Limit) 0.015-0.076 mm 0.0006-0.003 in
Connecting Rod Side Clearance 0.11-0.51 mm 0.00433-0.02 in
Crankshaft
Crankshaft Bearing Clearance (Production) 0.018-0.054 mm 0.0007-0.00212 in
Crankshaft Connecting Rod Journal Diameter (Production) 53.318-53.338 mm 2.0991-2.0999 in
Crankshaft Connecting Rod Journal Diameter (Service Limit) 53.308 mm (Minimum) 2.0987 in (Minimum)
Crankshaft Connecting Rod Journal Taper (Production) 0.005 mm (Maximum for 1/2 of Journal Length) 0.0002 in (Maximum for 1/2 of Journal Length)
Crankshaft Connecting Rod Journal Taper (Service Limit) 0.01 mm (Maximum) 0.0004 in (Maximum)
Crankshaft Connecting Rod Journal Out-of-Round (Production) 0.005 mm 0.0002 in
Crankshaft Connecting Rod Journal Out-of-Round (Service Limit) 0.01 mm 0.0004 in
Crankshaft End Play 0.04-0.2 mm 0.0015-0.0078 in
Crankshaft Main Journal Diameter (Production) 64.993-65.007 mm 2.558-2.559 in
Crankshaft Main Journal Diameter (Service Limit) 64.993 mm (Minimum) 2.558 in (Minimum)
Crankshaft Main Journal Out-of-Round (Production) 0.003 mm 0.000118 in
Crankshaft Main Journal Out-of-Round (Service Limit) 0.008 mm 0.0003 in
Crankshaft Main Journal Taper (Production) 0.01 mm 0.0004 in
Crankshaft Main Journal Taper (Service Limit) 0.02 mm 0.00078 in
Crankshaft Reluctor Ring Runout (Measured 1.0 mm (0.04 in) Below Tooth Diameter) 0.25 mm 0.01 in
Crankshaft Runout (at Rear Flange) 0.05 mm 0.002 in
Crankshaft Thrust Wall Runout 0.025 mm 0.001 in
Crankshaft Thrust Wall Width (Production) 26.14-26.22 mm 1.029-1.032 in
Crankshaft Thrust Wall Width (Service) 26.32 mm (Maximum) 1.036 in (Maximum)
Cylinder Bore
Cylinder Bore Diameter 99.0-99.018 mm 3.897-3.898 in
Cylinder Bore Taper Thrust Side 0.018 mm (Maximum) 0.0007 in (Maximum)
Cylinder Head
Cylinder Head Engine Block Deck Flatness (Measured within a 152.4 mm (6.0 in) area) 0.11 mm 0.004 in
Cylinder Head Engine Block Deck Flatness (Measuring the Overall Length of the Cylinder Head) 0.22 mm 0.008 in
Cylinder Head Exhaust Manifold Deck Flatness 0.22 mm 0.008 in
Cylinder Head Intake Manifold Deck Flatness 0.22 mm 0.008 in
Cylinder Head Height (Measured from the Cylinder Head Deck to the Valve Rocker Arm Cover Seal Surface) 120.2 mm (Minimum) 4.732 in (Minimum)
Engine Block
Camshaft Bearing Bore Diameters 55.063-55.088 mm 2.168-2.169 in
Engine Block Cylinder Head Deck Surface Flatness (Measured within a 152.4 mm (6.0 in) area) 0.11 mm 0.004 in
Engine Block Cylinder Head Deck Surface Flatness (Measuring the Overall Length of the Block Deck) 0.22 mm 0.008 in
Engine Block Cylinder Head Deck Height (Measuring from the Centerline of Crankshaft to the Deck Face) 234.57-234.82 mm 9.235-9.245 in
Main Bearing Bore Diameter (Production) 69.871-69.889 mm 2.750-2.751 in
Valve Lifter Bore Diameter (Production) 21.417-21.443 mm 0.843-0.844 in
Intake Manifold
Intake Manifold Cylinder Head Deck Flatness (Measured at Gasket Sealing Surfaces) 0.5 mm 0.02 in
Oil Pan and Front/Rear Cover Alignment
Oil Pan to Rear of Engine Block Alignment (at Transmission Bellhousing Mounting Surface) 0.0-0.25 mm (Maximum) 0.0-0.01 in (Maximum)
Front Cover Alignment (at Oil Pan Surface) 0.0-0.5 mm 0.0-0.02 in
Rear Cover Alignment (at Oil Pan Surface) 0.0-0.5 mm 0.0-0.02 in
Piston
Piston Outside Diameter (at Size Point) 98.964-98.982 mm 3.8962-3.8969 in
Piston to Bore Clearance (Production) 0.018-0.054 mm 0.0007-0.00212 in
Piston to Bore Clearance (Service Limit) 0.018-0.054 mm (Maximum) 0.0007-0.00212 in (Maximum)
Piston Pin
Piston Pin Clearance to Piston Bore (Production) 0.01-0.02 mm 0.0004-0.00078 in
Piston Pin Clearance to Piston Bore (Service Limit) 0.01-0.02 mm (Maximum) 0.0004-0.00078 in (Maximum)
Piston Pin Diameter 23.997-24.0 mm 0.9447-0.9448 in
Piston Pin Fit in Connecting Rod 0.02-0.043 mm (Interference) 0.00078-0.00169 in (Interference)
Piston Rings
Piston Compression Ring End Gap (Production Top) (Measured in Cylinder Bore) 0.23-0.38 mm 0.009-0.0149 in
Piston Compression Ring End Gap (Production--2nd) (Measured in Cylinder Bore) 0.44-0.64 mm 0.0173-0.0251 in
Piston Oil Ring End Gap (Production) (Measured in Cylinder Bore) 0.18-0.69 mm 0.007-0.0271 in
Piston Compression Ring End Gap (Service-Top) (Measured in Cylinder Bore) 0.23-0.38 mm (Maximum) 0.009-0.01496 in (Maximum)
Piston Compression Ring End Gap (Service--2nd)(Measured in Cylinder Bore) 0.44-0.64 mm (Maximum) 0.0173-0.0251 in (Maximum)
Piston Oil Ring End Gap (Service Limit) (Measured in Cylinder Bore) 0.18-0.69 mm (Maximum) 0.007-0.0271 in (Maximum)
Piston Compression Ring Groove Clearance (Production--Top) 0.04-0.085 mm 0.00157-0.003346 in
Piston Compression Ring Groove Clearance (Production--2nd) 0.04-0.08 mm 0.00157-0.003149 in
Piston Oil Ring Groove Clearance (Production) 0.01-0.22 mm 0.0004-0.00866 in
Piston Oil Ring Groove Clerance (Production)
Piston Compression Ring Groove Clearance (Service--Top) 0.04-0.085 mm (Maximum) 0.00157-0.003346 in (Maximum)
Piston Compression Ring Groove Clearance (Service--2nd) 0.04-0.08 mm (Maximum) 0.00157-0.003149 in (Maximum)
Piston Oil Ring Groove Clearance (Service Limit) 0.01-0.22 mm (Maximum) 0.0004-0.00866 in (Maximum)
Valve System
Valve Lifter Hydraulic Roller
Valve Rocker Arm Ratio 1.70:1
Valve Lash Net Lash--No Adjustment
Valve Face Angle 45 degrees
Valve Seat Angle 46 degrees
Valve Seat Runout 0.05 mm (Maximum) 0.002 in (Maximum)
Valve Seat Width (Intake) 1.02 mm 0.04 in
Valve Seat Width (Exhaust) 1.78 mm 0.07 in
Valve Stem Clearance (Production--Intake) 0.025-0.066 mm 0.001-0.0026 in
Valve Stem Clearance (Production--Exhaust) 0.025-0.066 mm 0.001-0.0026 in
Valve Stem Clearance (Service--Intake) 0.093 mm (Maximum) 0.0037 in (Maximum)
Valve Stem Clearance (Service--Exhaust) 0.093 mm (Maximum) 0.0037 in (Maximum)
Valve Stem Diameter (Production) 7.955-7.976 mm 0.313-0.314 in
Valve Stem Diameter (Service) 7.9 mm (Minimum) 0.311 in (Minimum)
Valve Spring Free Length 52.9 mm 2.08 in
Valve Spring Pressure (Closed) 340 N at 45.75 mm 76 lb at 1.80 in
Valve Spring Pressure (Open) 980 N at 33.55 mm 220 lb at 1.32 in
Valve Spring Installed Height (Intake) 45.75 mm 1.8 in
Valve Spring Installed Height (Exhaust) 45.75 mm 1.8 in
Valve Lift (Intake) 11.99 mm 0.472 in
Valve Lift (Exhaust) 12.15 mm 0.479 in
Valve Guide Installed Height (Measured from the Cylinder Head Spring Seat Surface to the Top of the Valve Guide) 17.32 mm 0.682 in
Valve Stem Oil Seal Installed Height (Measured from the ValveSpring Shim to Top Edge of Seal Body) 18.1-19.1 mm 0.712-0.752 in
Approximate Fluid Capacities
Cooling System
Automatic Transmission 11.6 Liters 12.3 quarts
Manual Transmission 11.9 Liters 12.6 quarts
Engine Crankcase
With Filter 6.1 Liters 6.5 quarts
Without Filter 5.7 Liters 6.0 quarts
Fuel Tanks (Total) 72.3 Liters 19.1 gallons
Rear Axle Differential
Lubricant 1.6 Liters 1.69 quarts
Limited-Slip Additive 118 Milliliters 4.0 ounces
Transmission Fluid
Drain & Fill (Automatic Transmission) 4.7 Liters 5.0 quarts
Overhaul (Automatic Transmission) 10.2 Liters 10.8 quarts
Overhaul (Manual Transmission) 3.9 Liters 4.1 quarts
jrp is offline
Old 09-06-2004, 06:47 PM
jrp
SN95 Director
jrp's Avatar
Stock Head Flow Numbers
HERE
jrp is offline
Old 09-06-2004, 06:49 PM
jrp
SN95 Director
jrp's Avatar
How to Compute Cubic Inches
((bore/2 * bore/2) * 3.1415) * stroke * cylinders = cubic inches
ie LS1:
3.9/2 * 3.9/2 = 1.95*1.95 = 3.8025 *3.1415 = 11.9456 * 3.622 = 43.2668 * 8 = 346.1344
swap in a 4" stroker crank and hone the cylinder .005 and you get
1.9525 * 1.9525 = 3.8123 *3.1415 = 11.9762 * 4 = 47.9048 * 8 = 383.2385
jrp is offline
Old 09-06-2004, 06:52 PM
jrp
SN95 Director
jrp's Avatar
How To Disable CAGS (computer aided gear select) M6 Only
Click Here
jrp is offline
Old 09-06-2004, 06:56 PM
jrp
SN95 Director
jrp's Avatar
Power Window Motor Replacement
Click Here
    jrp is offline
    Old 09-06-2004, 07:10 PM
      #32
    jrp
    SN95 Director
    jrp's Avatar
    HP vs TQ
    Torque vs Horsepower
    Bruce Augenstein, 2002-12-01
    There's been a certain amount of discussion, in this and other files, about the concepts of horsepower and torque, how they relate to each other, and how they apply in terms of automobile performance. I have observed that, although nearly everyone participating has a passion for automobiles, there is a huge variance in knowledge. It's clear that a bunch of folks have strong opinions (about this topic, and other things), but that has generally led to more heat than light, if you get my drift :-). I've posted a subset of this note in another string, but felt it deserved to be dealt with as a separate topic. This is meant to be a primer on the subject, which may lead to serious discussion that fleshes out this and other subtopics that will inevitably need to be addressed.
    OK. Here's the deal, in moderately plain English.
    Force, Work and Time
    If you have a one pound weight bolted to the floor, and try to lift it with one pound of force (or 10, or 50 pounds), you will have applied force and exerted energy, but no work will have been done. If you unbolt the weight, and apply a force sufficient to lift the weight one foot, then one foot pound of work will have been done. If that event takes a minute to accomplish, then you will be doing work at the rate of one foot pound per minute. If it takes one second to accomplish the task, then work will be done at the rate of 60 foot pounds per minute, and so on.
    In order to apply these measurements to automobiles and their performance (whether you're speaking of torque, horsepower, newton meters, watts, or any other terms), you need to address the three variables of force, work and time.
    Awhile back, a gentleman by the name of Watt (the same gent who did all that neat stuff with steam engines) made some observations, and concluded that the average horse of the time could lift a 550 pound weight one foot in one second, thereby performing work at the rate of 550 foot pounds per second, or 33,000 foot pounds per minute, for an eight hour shift, more or less. He then published those observations, and stated that 33,000 foot pounds per minute of work was equivalent to the power of one horse, or, one horsepower.
    Everybody else said OK. :-)
    For purposes of this discussion, we need to measure units of force from rotating objects such as crankshafts, so we'll use terms which define a *twisting* force, such as foot pounds of torque. A foot pound of torque is the twisting force necessary to support a one pound weight on a weightless horizontal bar, one foot from the fulcrum.
    Now, it's important to understand that nobody on the planet ever actually measures horsepower from a running engine. What we actually measure (on a dynomometer) is torque, expressed in foot pounds (in the U.S.), and then we *calculate* actual horsepower by converting the twisting force of torque into the work units of horsepower.
    Visualize that one pound weight we mentioned, one foot from the fulcrum on its weightless bar. If we rotate that weight for one full revolution against a one pound resistance, we have moved it a total of 6.2832 feet (Pi * a two foot circle), and, incidently, we have done 6.2832 foot pounds of work.
    OK. Remember Watt? He said that 33,000 foot pounds of work per minute was equivalent to one horsepower. If we divide the 6.2832 foot pounds of work we've done per revolution of that weight into 33,000 foot pounds, we come up with the fact that one foot pound of torque at 5252 rpm is equal to 33,000 foot pounds per minute of work, and is the equivalent of one horsepower. If we only move that weight at the rate of 2626 rpm, it's the equivalent of 1/2 horsepower (16,500 foot pounds per minute), and so on. Therefore, the following formula applies for calculating horsepower from a torque measurement:
    Horsepower = (Torque * RPM) / 5252
    This is not a debatable item. It's the way it's done. Period.
    The Case For Torque
    Now, what does all this mean in carland?
    First of all, from a driver's perspective, torque, to use the vernacular, RULES :-). Any given car, in any given gear, will accelerate at a rate that *exactly* matches its torque curve (allowing for increased air and rolling resistance as speeds climb). Another way of saying this is that a car will accelerate hardest at its torque peak in any given gear, and will not accelerate as hard below that peak, or above it. Torque is the only thing that a driver feels, and horsepower is just sort of an esoteric measurement in that context. 300 foot pounds of torque will accelerate you just as hard at 2000 rpm as it would if you were making that torque at 4000 rpm in the same gear, yet, per the formula, the horsepower would be *double* at 4000 rpm. Therefore, horsepower isn't particularly meaningful from a driver's perspective, and the two numbers only get friendly at 5252 rpm, where horsepower and torque always come out the same.
    In contrast to a torque curve (and the matching pushback into your seat), horsepower rises rapidly with rpm, especially when torque values are also climbing. Horsepower will continue to climb, however, until well past the torque peak, and will continue to rise as engine speed climbs, until the torque curve really begins to plummet, faster than engine rpm is rising. However, as I said, horsepower has nothing to do with what a driver *feels*.
    You don't believe all this?
    Fine. Take your non turbo car (turbo lag muddles the results) to its torque peak in first gear, and punch it. Notice the belt in the back? Now take it to the power peak, and punch it. Notice that the belt in the back is a bit weaker? Fine. Can we go on, now? :-)
    The Case For Horsepower
    OK. If torque is so all-fired important, why do we care about horsepower?
    Because (to quote a friend), "It is better to make torque at high rpm than at low rpm, because you can take advantage of *gearing*.
    For an extreme example of this, I'll leave carland for a moment, and describe a waterwheel I got to watch awhile ago. This was a pretty massive wheel (built a couple of hundred years ago), rotating lazily on a shaft which was connected to the works inside a flour mill. Working some things out from what the people in the mill said, I was able to determine that the wheel typically generated about 2600(!) foot pounds of torque. I had clocked its speed, and determined that it was rotating at about 12 rpm. If we hooked that wheel to, say, the drivewheels of a car, that car would go from zero to twelve rpm in a flash, and the waterwheel would hardly notice :-).
    On the other hand, twelve rpm of the drivewheels is around one mph for the average car, and, in order to go faster, we'd need to gear it up. To get to 60 mph would require gearing the wheel up enough so that it would be effectively making a little over 43 foot pounds of torque at the output, which is not only a relatively small amount, it's less than what the average car would need in order to actually get to 60. Applying the conversion formula gives us the facts on this. Twelve times twenty six hundred, over five thousand two hundred fifty two gives us:
    6 HP.
    Oops. Now we see the rest of the story. While it's clearly true that the water wheel can exert a *bunch* of force, its *power* (ability to do work over time) is severely limited.
    jrp is offline
      #33
    jrp
    SN95 Director
    jrp's Avatar
    At The Dragstrip
    OK. Back to carland, and some examples of how horsepower makes a major difference in how fast a car can accelerate, in spite of what torque on your backside tells you :-).
    A very good example would be to compare the current LT1 Corvette with the last of the L98 Vettes, built in 1991. Figures as follows:
    Engine Peak HP @ RPM Peak Torque @ RPM
    L98 250 @ 4000 340 @ 3200
    LT1 300 @ 5000 340 @ 3600
    The cars are geared identically, and car weights are within a few pounds, so it's a good comparison.
    First, each car will push you back in the seat (the fun factor) with the same authority - at least at or near peak torque in each gear. One will tend to *feel* about as fast as the other to the driver, but the LT1 will actually be significantly faster than the L98, even though it won't pull any harder. If we mess about with the formula, we can begin to discover exactly *why* the LT1 is faster. Here's another slice at that formula:
    Torque = Horsepower * 5252 / RPM
    If we plug some numbers in, we can see that the L98 is making 328 foot pounds of torque at its power peak (250 hp @ 4000), and we can infer that it cannot be making any more than 263 pound feet of torque at 5000 rpm, or it would be making more than 250 hp at that engine speed, and would be so rated. In actuality, the L98 is probably making no more than around 210 pound feet or so at 5000 rpm, and anybody who owns one would shift it at around 46-4700 rpm, because more torque is available at the drive wheels in the next gear at that point.
    On the other hand, the LT1 is fairly happy making 315 pound feet at 5000 rpm, and is happy right up to its mid 5s redline.
    So, in a drag race, the cars would launch more or less together. The L98 might have a slight advantage due to its peak torque occuring a little earlier in the rev range, but that is debatable, since the LT1 has a wider, flatter curve (again pretty much by definition, looking at the figures). From somewhere in the mid range and up, however, the LT1 would begin to pull away. Where the L98 has to shift to second (and throw away torque multiplication for speed), the LT1 still has around another 1000 rpm to go in first, and thus begins to widen its lead, more and more as the speeds climb. As long as the revs are high, the LT1, by definition, has an advantage.
    Another example would be the LT1 against the ZR-1. Same deal, only in reverse. The ZR-1 actually pulls a little harder than the LT1, although its torque advantage is softened somewhat by its extra weight. The real advantage, however, is that the ZR-1 has another 1500 rpm in hand at the point where the LT1 has to shift.
    There are numerous examples of this phenomenon. The Integra GS-R, for instance, is faster than the garden variety Integra, not because it pulls particularly harder (it doesn't), but because it pulls *longer*. It doesn't feel particularly faster, but it is.
    A final example of this requires your imagination. Figure that we can tweak an LT1 engine so that it still makes peak torque of 340 foot pounds at 3600 rpm, but, instead of the curve dropping off to 315 pound feet at 5000, we extend the torque curve so much that it doesn't fall off to 315 pound feet until 15000 rpm. OK, so we'd need to have virtually all the moving parts made out of unobtanium :-), and some sort of turbocharging on demand that would make enough high-rpm boost to keep the curve from falling, but hey, bear with me.
    If you raced a stock LT1 with this car, they would launch together, but, somewhere around the 60 foot point, the stocker would begin to fade, and would have to grab second gear shortly thereafter. Not long after that, you'd see in your mirror that the stocker has grabbed third, and not too long after that, it would get fourth, but you'd wouldn't be able to see that due to the distance between you as you crossed the line, *still in first gear*, and pulling like crazy.
    I've got a computer simulation that models an LT1 Vette in a quarter mile pass, and it predicts a 13.38 second ET, at 104.5 mph. That's pretty close (actually a tiny bit conservative) to what a stock LT1 can do at 100% air density at a high traction drag strip, being powershifted. However, our modified car, while belting the driver in the back no harder than the stocker (at peak torque) does an 11.96, at 135.1 mph, all in first gear, of course. It doesn't pull any harder, but it sure as hell pulls longer :-). It's also making *900* hp, at 15,000 rpm.
    Of course, folks who are knowledgeable about drag racing are now openly snickering, because they've read the preceding paragraph, and it occurs to them that any self respecting car that can get to 135 mph in a quarter mile will just naturally be doing this in less than ten seconds. Of course that's true, but I remind these same folks that any self-respecting engine that propels a Vette into the nines is also making a whole bunch more than 340 foot pounds of torque.
    That does bring up another point, though. Essentially, a more "real" Corvette running 135 mph in a quarter mile (maybe a mega big block) might be making 700-800 foot pounds of torque, and thus it would pull a whole bunch harder than my paper tiger would. It would need slicks and other modifications in order to turn that torque into forward motion, but it would also get from here to way over there a bunch quicker.
    On the other hand, as long as we're making quarter mile passes with fantasy engines, if we put a 10.35:1 final-drive gear (3.45 is stock) in our fantasy LT1, with slicks and other chassis mods, we'd be in the nines just as easily as the big block would, and thus save face :-). The mechanical advantage of such a nonsensical rear gear would allow our combination to pull just as hard as the big block, plus we'd get to do all that gear banging and such that real racers do, and finish in fourth gear, as God intends. :-)
    The only modification to the preceding paragraph would be the polar moments of inertia (flywheel effect) argument brought about by such a stiff rear gear, and that argument is outside of the scope of this already massive document. Another time, maybe, if you can stand it :-).
    At The Bonneville Salt Flats
    Looking at top speed, horsepower wins again, in the sense that making more torque at high rpm means you can use a stiffer gear for any given car speed, and thus have more effective torque *at the drive wheels*.
    Finally, operating at the power peak means you are doing the absolute best you can at any given car speed, measuring torque at the drive wheels. I know I said that acceleration follows the torque curve in any given gear, but if you factor in gearing vs car speed, the power peak is *it*. An example, yet again, of the LT1 Vette will illustrate this. If you take it up to its torque peak (3600 rpm) in a gear, it will generate some level of torque (340 foot pounds times whatever overall gearing) at the drive wheels, which is the best it will do in that gear (meaning, that's where it is pulling hardest in that gear).
    However, if you re-gear the car so it is operating at the power peak (5000 rpm) *at the same car speed*, it will deliver more torque to the drive wheels, because you'll need to gear it up by nearly 39% (5000/3600), while engine torque has only dropped by a little over 7% (315/340). You'll net a 29% gain in drive wheel torque at the power peak vs the torque peak, at a given car speed.
    Any other rpm (other than the power peak) at a given car speed will net you a lower torque value at the drive wheels. This would be true of any car on the planet, so, theoretical "best" top speed will always occur when a given vehicle is operating at its power peak.
    "Modernizing" The 18th Century
    OK. For the final-final point (Really. I Promise.), what if we ditched that water wheel, and bolted an LT1 in its place? Now, no LT1 is going to be making over 2600 foot pounds of torque (except possibly for a single, glorious instant, running on nitromethane), but, assuming we needed 12 rpm for an input to the mill, we could run the LT1 at 5000 rpm (where it's making 315 foot pounds of torque), and gear it down to a 12 rpm output. Result? We'd have over *131,000* foot pounds of torque to play with. We could probably twist the whole flour mill around the input shaft, if we needed to :-).
    The Only Thing You Really Need to Know
    Repeat after me. "It is better to make torque at high rpm than at low rpm, because you can take advantage of *gearing*." :-)
    jrp is offline
    Old 09-06-2004, 07:32 PM
      #34
    jrp
    SN95 Director
    jrp's Avatar
    How To Do A Burn Out
    First make sure Traction Control is disengaged (if you have it)!
    Automatic: Use your left foot to step on the brake just enough to prevent the car from rolling forward, then, with your right foot, slam down the gas. Slowly release brake when you want to start moving.
    Manual: Put the shifter into 1st gear. (Some people do 2nd, see what works best for you). Push the clutch in and rev it up to about 4k RPMs, then quickly remove your foot from the clutch pedal and move it over to the brake pedal. The idea is to use as little braking force as necessary to prevent the car from rolling forward. When you want to make your getaway, simply slowly release the brake pedal and you should start moving forward and leave some nice tire marks in the process!
    A line lock is a device that is connected to the brake lines going to the front tires. This will allow the driver to engage only the front brakes, so that the rear brake pads are not burnt away as you do your burn out.
    - Bomax
    jrp is offline
    Old 09-06-2004, 07:35 PM
      #35
    jrp
    SN95 Director
    jrp's Avatar
    How To Change your Plugs/Wires
    Click Here
            jrp is offline
            Old 09-06-2004, 07:38 PM
              #36
            jrp
            SN95 Director
            jrp's Avatar
            How To Change your Oil
            Click Here
              jrp is offline
              Old 09-06-2004, 07:44 PM
                #37
              jrp
              SN95 Director
              jrp's Avatar
              2 Sites you need to Bookmark and Read Religiously
                  jrp is offline
                  Old 09-06-2004, 10:18 PM
                    #38
                  jrp
                  SN95 Director
                  jrp's Avatar
                  GM Service Material
                  jrp is offline
                  Old 09-06-2004, 10:29 PM
                    #39
                  jrp
                  SN95 Director
                  jrp's Avatar
                  Newbie Mod Mistakes
                  Click Here
                    jrp is offline
                    Old 09-06-2004, 10:42 PM
                      #40
                    jrp
                    SN95 Director
                    jrp's Avatar
                    4th Gen Lube Changes
                    Click Here
                      jrp is offline
                      Quick Reply: JRP's FAQ For Commonly Asked Questions
