Could these codes all be from my GMS MAF?
Whoever had my T/A before me installed a Granatelli MAF sensor. I bought it in November and it's had the following trouble codes ever since I've owned it...
P0420 Catalyst System Efficiency Below Threshold(Bank 1)
P0430 Catalyst System Efficiency Below Threshold(Bank 2)
P0327 Knock Sensor 1 Circuit Low Input(Bank 1 or Single Sensor)
P0171 System Too Lean (Bank 1)
Then 2 days ago another code showed up...
P0174 System Too Lean (Bank 2)
Is it possible that all these codes could be caused by the Granatelli MAF? If not, what else could they be caused by?
Thanks in advance.
Thanks in advance.
Do you have an off road y pipe on your car? I have seen cars with bad MAF's that do throw lean codes. It is quite possible that some of the codes are cause by a bad MAF.
Could my car running lean cause the knock sensor code to show up?
Thanks for your help.
Originally Posted by calys968
No, my car is pretty much stock except for the Granatelli MAF.
