Should I have more top end?
Old 03-18-2005, 04:20 AM
Nocturnal SS's Avatar
Question Should I have more top end?
I have a 2002 Camaro SS my best time is a 12.01 at 112.74. MY mods are
3200 stall speed converter
216/220 cam 114 lsa
Pacesetter Headers with high flow cats
BFG Drag radials
Went to the track Tuesday night 60 ft were good but my mph seem to be a bit off. The first run was an 111.40 then 111.20, 111.02, 109.91, 112.06,and 111.40. Asked a friend who worked on the car he said could be the converter slipping a little because some of the runs were made back to back, or it could be the knock sensor pulling timing out of the car.I would not be curious if the weather was not good , but the weather was pretty good. Anyway my 2 question are do you thing the converter is slipping, and if it was whould I not feel that when I am driving the car? By the way doe's the Vigilante torque converter lock up?
Old 03-18-2005, 11:12 AM
BlueSix's Avatar
A4 cars simply don't trap as high as M6 cars. The stall will also eat up a couple MPH.
Old 03-18-2005, 11:59 AM
jrp
SN95 Director
jrp's Avatar
do you have any previous trap speeds to compared with the new ones?
Old 03-19-2005, 12:22 AM
Default Yes.
Yes I do. In weather like we had on Tuesday night I went in the 112 range.
Old 03-19-2005, 01:33 AM
BlueSix's Avatar
the 'verter wont lock under WOT, and you really don't want it to.
Also that cam you have isn't exactly a "top end" cam.
Old 03-19-2005, 10:52 AM
02transhawk's Avatar
I would suggest to play with the tire pressure, and give the car a lil break in between runs, compare your 60' times to top end a figure out the best result the don't sacrifice that 12sec run, maybe even with the right config, you will get into the 11's. I don't think the top end is having anything to do with the converter.
Old 03-20-2005, 03:56 AM
Cool Converter could be slipping.
I called TSP, and asked a few friends they said it could be the Converter slipping, because it got hot when I made 3 passes in a row. So I put a trans cooler on it ,and change the trans fluid.
Old 03-21-2005, 01:09 AM
Question I do.
I leave 32 pounds in the front.
I take the BFG Drag radials down to 17
How much of a break in between runs do you suggest?
I usually make 2 runs then let it cool down for about 20 to 30 mins.
This time I made 3 back to back runs.
Old 03-21-2005, 01:57 AM
2MuchRiceMakesMeSick's Avatar
What kind of 60' times are you getting?
Old 03-21-2005, 01:45 PM
Keenov's Avatar
Quit hot lapping
Old 03-23-2005, 03:28 AM
Default Good 60 ft.
In the 1.72 to 1.74 range.
By the way, before the headers I dyno 353 HP 375 torque STD.
Old 03-23-2005, 02:16 PM
BlueSix's Avatar
Those are decent numbers through the stalled A4. Especially without headers.
Old 03-24-2005, 02:16 AM
Question What do you think?
Thank"s BLUESIX. I forgot to mention that the car was not tune on a dyno.
Called TSP today they said change the spark plug wires.
What do you think? The spark plugs themselfs were change when the headers were put in.
Old 03-24-2005, 11:00 AM
BlueSix's Avatar
I would personally throw the car on a dyno and get a tune. Whoever does the tune will be able to tell you if there's anything in the combo that needs adjusting. Plug wires might help, but i've always heard goot things about the stockers.
Old 03-27-2005, 02:43 PM
hawkls1's Avatar
I'm a friend of nocturnal ss. does the A4 conveter lock up under WOT.and if it does what mph does it. thanks guys
Old 03-30-2005, 01:40 AM
Question Question?
Everyone has differant opinions about this one
