Retarded blinker question...
Old 04-20-2005, 06:46 PM
Frosty's Avatar
Default Retarded blinker question...
This is gonna sound retarded but my right turn signal won't work. Both bulbs work but it won't actually flash. WTF do I replace?
Old 04-20-2005, 07:04 PM
Another_User's Avatar
More blinker fluid? Try the blinker relay first, if that isn't it then the blinker switch on the steering column needs replacement.
Old 04-20-2005, 07:12 PM
Frosty's Avatar
Where is the relay at? I couldn't find it in the manual
and I PRAY it's not the switch in the colum...a REAL PITA, at least it was on my thirdgens
Old 04-20-2005, 07:13 PM
Copy & Paste Moderator
VIP1's Avatar
The bulbs are dual filament.
Just because they are on with the parking lights doesnt mean they work. Turn on the hazards and see which signals dont blink. The ones that dont blink are the ones that need to be replaced. The hazards use a separate (heavier duty) flasher unit. That is why this test works. The flashers in the f-body are thermal which are affected (stop working or work faster) by lights going out.
If one side works and the other side doesnt, then the peoblem is not the flasher unit becuase both sides use the same flasher unit. If both sides dont work, then it probably is the flasher unit. They are located behind the shin panel under the steering wheel. When you pull off the panel look to the right side of that area.
Also a search would have answered your question.
Here is one such thread to get you started:
https://ls1tech.com/forums/showthrea...hlight=blinker
Old 04-20-2005, 07:17 PM
Frosty's Avatar
I just found that before you post :doh:
Thanks!
Old 04-20-2005, 08:55 PM
Man, thats some good info.
Old 04-20-2005, 09:19 PM
Frosty's Avatar
It was just the bulb. I'll replace it tomorrow...didn't look at how(totally new to 4thgens here). I imagine it cant be too hard.
Old 04-21-2005, 04:53 PM
VIP1's Avatar
i updated my post...i realized that i said left side under panel instead of right side.
The flasher relays are to the right.
Some times i need to tatoo left & right on my hands
Old 04-21-2005, 05:08 PM
Ravenkel's Avatar
Had same issue, the left worked fine, but the right blinker intermittently blinked, or it went on but stayed solid. Replace bulbs but also at the same time cleaned out some of the corrosion on the bulb receptacle, and now it works fine
Old 04-21-2005, 06:16 PM
Frosty's Avatar
Yeah it's the bulb...but I can't get my had down there to change it
Old 04-23-2005, 04:08 PM
Bart01SS's Avatar
It took another person to help me change mine. had to pull the plastic back. pain in the ***
Old 04-23-2005, 05:50 PM
soundengineer's Avatar
Originally Posted by Another_User
More blinker fluid?
thats a classic..... I had somebody actually believe me once when I was joking like that...
Old 04-24-2005, 12:50 AM
Frosty's Avatar
I swear it's THE MOST retarded design ever.
I know I sound stupid saying it was a real PITA trying to change a simple bulb but it was...
Good 'ol GM engineering lol
