Which Gel top battery?!??!?
Any suggestions, need to replace battery and wanted to switch to a gel top, any suggestions???
I know for stereo setups, I've used Yellow top before, but for performance does anyone suggest a different one??
Cheers
Cheers
I use the red top it has more cranking amps than the yellow so on cold days it cranks right up. If you like to leave your car running and listen to the radio a yello top might be what you want. A yellow top can be run dead by accident or by purpose and you will still be able to crank your car back up and it will re-charge running.
