need your quick opinions... ls6 intake of asp pullies for my 98ls1
i just got some extra cash left over from my taxes and im wondering which upgrade to go with, im thinking either an ls6 intake since i have a 98 or maybe a set of asp pullies, both i think give an extra 10 or so, which one would be best??? need your opinions !!!!!!!!!! thanks guys
Both are great mods. I gained 10 rwhp with the pullies and 0.15 secs at the track. The pullies will be cheaper so, it is up to you. With the LS6 Intake, you will need the intake, coolant tubes and tuning. The tuning is for the EGR that you won't be using anymore. Also, with the increased airflow the fueling and spark could be further optimized. The pullies work great on a stock car.
Moderator
Intake. You can get a used one on the boards for $300 shiped. I just sold mine for that locally. You need a front coolant line & rear block off plugs ($30) You will also need block off plates for the EGR on the exhaust manifold ($40 w/ air block offs too, ebay) You can do the intake yourself in a day. an hour if you are good.
The crank pully is a bitch to remove.
