HP Specs on 350 w/ Holley
I have a 86 Chevy 350SB. I have the following parts for it, including headwork:
-750 Holley Carb
-Holley 14PSI Electric Fuel Pump
-Comp Cam Coils 273Lbs@1.250
-Edelbrock "Torquer II" Intake Manifold
-MSD wires and entire electric upgrades all MSD
-Hedman Longtube Headers
-All New Gaskets
-3.73 Rear Gears
-5Spd Manual Tranny *(Rebuilt)
-Upgraded Pulley Kit
-3 Inch Exhaust w/ H-Pipe to Dual Exhaust exiting rear of car
Thats all I can think of right now. I know there are a few more parts. But I am not going to mess with the pistons or crank for right now, maybe in the near future I will bore it out and upgrade crank. But, Can you guys help give an educated guess on what this set up will be pushing??
-750 Holley Carb
-All New Gaskets
-3.73 Rear Gears
Hard to say.....You're leaving out lots of info like combustion chamber size (what's the head casting #'s?), compression ratio and whether the cam is stock or not. If they're run of the mill smog heads & dished pistons with a stockish cam I'd say you're probably somewhere around 280-300hp at the flywheel, give or take.
The cam is far from stock, so is everything else. My friends say it should be in the 400-450 range, but Im looking for other opinions. And yeah, I've posted 3 threads on important questions concerning my situation with the Z28. I am in the middle of major work and that is what this place is for. Can some body direct me to an oldschool forum?
