whats the difference????
Old 01-14-2007, 03:47 PM
transamfreak01's Avatar
Default whats the difference????
what exactly is the difference between spherical rod ends and not??? is it worth the money?
Old 01-14-2007, 08:00 PM
Copy & Paste Moderator
VIP1's Avatar
Curtesy of www.tbyrne.com
Rod Ends:
Poly Ends:
Old 01-14-2007, 08:04 PM
2_wacko's Avatar
If you have a daily driver get the Poly Ends.
Old 01-14-2007, 08:30 PM
VIP1's Avatar
If you care about handling, get the rod ends.
If you want a compromise, get a poly/rod set.
(poly on the body side and rod on the axle side)
If you want to save some money, get 1LE bushings pressed into the stock LCAs.
Old 01-14-2007, 11:17 PM
yeah so would spending the extra money on spherical be a waste of money for me?? my car isnt a DD jus a weekend car and might see the track 1 or 2 times a year
Old 01-15-2007, 10:16 PM
VIP1's Avatar
What kind of track?
Old 01-16-2007, 09:24 AM
lsx24's Avatar
Generally speaking rod ends on the PH bar are good, you will not notice any increased harshness or vibrations. LCAs are debateable if it's worth rod ends, if you are performance oriented, get poly/rod combination, or look into making your own. Lots of people go this route, for much cheaper and still good quality, with rod ends.
Rod ends are going to transmit more noise and vibration into the cabin, you will also notice some additional harshness in the ride. IF you are not a daily driver, you can probably put up with it, it will handle better (corner carving). Drag racing is slightly different, but the main rules still apply.
