Very important Ls6 questions
Old 04-23-2007, 09:49 AM
LSxZ/28-85's Avatar
Default Very important Ls6 questions
ok i just bought an ls6 block that jsut had the rotatign assembly and some of the piston material has flaked off no damage, but i am going to get the block bored over .007in and i am gonna get it clean. but any who are these parts listed every thign i need to make it a complete engien, because i already have the rotatign assembly. i jsut want soem people to double check me i am pretty sure i have evry thign i jsut want a secodn opinion.
soo if you see any tihgn i have to add PM me and if u have any of those parts for sale at a resonable price and not crap PM me as well thankx
btw
-no fuel pump nessisary, pressure regulator (got that covered)
-no egr, or o2 sensors nessisary, i am going to but this engien in my 1985 camaro z28 and i am goign to edit the computer
wiring harness,
heads With complete valve train
cam, (timing chain or direct conection u know with the gears)
vibration dampner
timing chain cover
push rods, lifters
pistons plus rings (not cracked)
Fbody oil pan(ls1 oil pan)
oil pump
fly wheel, bellhousing
fuel injectors + rails
coil packs + Maybe spark plugs
power steerign pump, alternator, fan, water pump, also the idler pully
intake manifold throttle body+throttle
and all the senders,
ls6 valley cover
freeze plugs
thermostat
oil plugs
gaskets
new berrigns for crank, rods and cams
and is a cam positioning sensor really nessisary/
Old 04-23-2007, 11:14 AM
jbuerke142's Avatar
pm sent
