Water in floor from A/C
Old 09-02-2007, 11:57 PM
ls1blackss's Avatar
Default Water in floor from A/C
Well today i noticed there is water in the passenger side floor from the a/c. what does this mean? I havent had time to look at it yet but will try to tomorow.
Old 09-03-2007, 12:00 AM
Black_Bird's Avatar
Are you sure it's from the A/C? Any smell?
Old 09-03-2007, 12:08 AM
SmaknaSS's Avatar
My girlfriend has the same problem. I even by passed the heater core just to make sure it's not coming from that but I still have water from the air conditioning. It's just one more thing I got to fix.
Old 09-03-2007, 12:10 AM
2000_SS's Avatar
my buddy has a '02 firehawk that does this....i'm gonna keep an eye out for him in case someone figures this out...
Old 09-03-2007, 01:03 AM
ls1blackss's Avatar
yea im sure its the a/c. it only does it when its on and its cool water and has not smell.
Old 09-03-2007, 01:06 AM
Fibbado's Avatar
I got water on the passenger side floor but I think it was coming from a rubber plug in the firewall that fell out.
Old 09-03-2007, 03:59 AM
Black_Bird's Avatar
The VERY first thing I would check is the evaporator drain plug to be loose, misrouted, plugged, etc. It's the leading cause of this and is easy to check. Have had a few customer cars in the past with the same problem.
Old 09-03-2007, 12:16 PM
johnnywhale's Avatar
If its clear water on the floor its condensation from the a/c. Like Black Bird says its the evaporator drain. Look outside the pass. firewall for a short rubber tube about 1/2 way down. Blow a little shop air, use a wire or a pipe cleaner in it. You'll dislodge a leaf or some crud and the water will then drain. Its why all cars with a/c leak water behind the r/f tire on a muggy day.
Johnny
Old 09-03-2007, 12:25 PM
*98TransAm*'s Avatar
^^^what he said, the same thing happened to me awhile back and all it took was some shop air
Old 09-03-2007, 04:30 PM
2002TAWS6Pontiac's Avatar
https://ls1tech.com/forums/new-ls1-owners-newbie-tech/730709-c-leaking-inside-floorboard.html
go to that thread i started, had the same problem like he said just take a air gun to it and clear out the drain, in one post there is a pic showing where it is.
Old 09-04-2007, 05:37 PM
93redBIRDman's Avatar
Happened to me recently. Go under your car, locate a black resevior with a small hole in it to the right of your passenger side cat (thats where it was on my car at least). My drain hole was clogged with dirt so I stuck a wire up into it and cleared it out. dont stick too far though, might damage something. Hope this helps
Old 09-04-2007, 05:40 PM
ICEMAN 31's Avatar
get your local mechanic to lift her up and use an airgun to loosen the gunk that is clogging your drain. Then watch it rain.
Old 09-05-2007, 01:36 AM
ls1blackss's Avatar
got up under it today and got it all cleaned out. thanks guys for the info.
Old 09-05-2007, 11:08 AM
no prob i felt your pain also 6 months ago
Old 09-05-2007, 11:20 AM
coreyslude's Avatar
this helped me out to same problem but different vehicle
