ABS question
((((((Administrator))))))
No.
3 channel = 2 front wheels + 1 axle ring gear / excitor wheel ring sensor
4 channel same as above but no axle sensor. There are sensors on the ends of the axles behind the calipers.
I don't think the sensor is the same, the exciter ring gears are way different in size too. Plus your PCM is not set up for it and also you need ABS gears pressed onto each axle.
Peace,
Craig.
Peace,
Craig.
