Difference between the iron blocks?
About to buy parts for a new engine build for my 98 TA. Going with a 6.0 iron block for the N2O set up that I have.
My question: Are the LQ4 & LQ9 two different blocks? Or are they just two different factory combinations using the same block? Did a search and couldn't find anything clear cut on it.
Last question: Am I correct in thinking the L92 heads will bolt up to an iron block?
Thanks in advance...
Steve... LT1 guy, LOL...
Warning: Bad Trader
They Are The Same Block Just Different Numbers Just That The Lq9 Block Everyone Knows About And Yea The L92 Heads Will Bolt Right Up I Use To Have Them On My Lq9 Block You Just Need Different Head Bolts You Need The Same Length Head Bolts
