help with exhaust?
help with exhaust?
ok i know very very little about these cars but i looked under my 99 TA and it has a y-pipe with no cats at all and my engine light is coming on. what little ive found is the cats and the o2 sensors causing this.
my car boggs down and im guessing this is the reason?
If so how can i get rid of this problem without putting them back on?
I know nothing of tuning so if you say it needs to be tuned tell me a good place in texas (northern) or if theres an easier/cheaper way
thanks
thanks
ok guys thanks for the feedback so far ill go to autozone and see whats up then repost in this topic
ive noticed when i floor it that it bogs down really bad could that be a reason?
As long as you don't have to worry about emissions, just leave the cats off. The problems you're describing don't sound related to cats or rear o2 sensors at all. If you DID have cats, then the bogging could be related to a plugged cat.
Is that all they said? Did they give you the code? AZ might be right, but I can't tell you how many times I've heard of some jackass at autozone telling people they need to replace something because the code description had a part name in it. They think that since you had an o2 code, it must be a bad o2 sensor. Didn't mean to rant there, but I deal with that a lot.
yeah they didnt give me a code exactly but they said it had a o2 code and a cat code but the cat code idc because i dont need to have them to pass but the front o2's have probably never been replaced and i dont think i need the rear ones seeing as i dont have a cat anyway
Yeah, depends on what the code is to know for sure if you need o2's. If the car has some milage on it, you may want to just go ahead and replace the front ones anyway. They tend to get lazy over time. Does it bog all the time?
If the code was for the o2 heaters then it's usually the sensors because the heating elements burn up over time. An easy way to check if your elements are bad is with an ohmmeter. Do a resistance ckeck on the o2 connector between the 2 wires that are the same color. I you have infinate resistance, then you will need to replace the sensor. The o2s don't read correctly til they get to 600deg f. The heating elements help em heat up faster to start sending voltage to the pcm. If your elements aren't heating the sensors, then they take a while to get warmed up by the hot exhaust.
ok it was the o2 sensors i ordered 2 of them offline im gonna put deletes in the back 2 because i dont have cats hopefully this will fix the problem if not its probly the MAF sensor
yea keep in mind that you need no prior experience with cars to get a job at autozone. i went in there asking which part # the k&n air filter would be and it took me about 3 minutes of explaining to get them to understand what i was talking about...i havent met a single car knowledgebale person at either autozone near me. they just type it in on the computer and tell you exactly what it says...
ok if thats so then what could cause my engine to bog down when i try and go WOT it just revs and barely goes even after its warmed up. i have to slowly accelerate for it to get up to the speed limit on the highway
