Whats Next [Suggestions Needed]
Ok first off I'll list the mods and the specs of which i know for sure.The Car was dyno'd with 441rwhp and 414rwtq. The car is N/A
Dyno Sheet-
LQ9 cnc handported heads
http://store.summitracing.com/partde...5&autoview=sku
208 intake valve
155 exhaust valve
bronze guides
milled .030
double springs/titanium retainers
236/236 single pattern comp cam - Was told 236/236 with i believe a high 500 lift. also i think the lobe is 112
hooker long tube headers and ORY
borla with elec cutout where plates would be
moser 12 bolt w/410's
ported TB
lid w/k+n and smooth bellow
tune
granitelli stuff
lower control arms
panhard rod
KYG adj. shocks
So my question is, with the given numbers is it right on track where it should be?
Also I'm looking to keep in N/A. But if some reason or some ungodly reason i decide to put a bottle on it b.c i get beat by a ricer or something along those lines. What type of power would i be looking at with each nitrious setup, ie-dry,wet etc.. Or even a turbo or SC
Besides the bottle i ask you that know alot more than i do. Whats next for the car? Im not looking to make it a full blown drag car by any means i would just like to be flirting with 500rwhp, preferablly without the forced power( boost or bottle)
Thanks ahead of time
Jacob
Dyno Sheet-
208 intake valve
155 exhaust valve
bronze guides
milled .030
ported TB
tune
granitelli stuff
lower control arms
panhard rod
KYG adj. shocks
Jacob
First off the numbers look good for the mods. But with a nice heads/cam setup like that you would really benifit from a fast 92 intake and appropriate throttle body. I could see you gaining 20 rwhp from the new intake with a tune.
Other then that I would also suggest an underdrive pulley. That could gain another 5-10 rwhp. The intake and pulley could get you 460-470 rwhp give or take.
500 rwhp N/A is definately doable but you would need a bigger cam like a Trex or MS4
As far as N20 goes, I wouldn't advise it. Adding N20 to an all ready stout NA setup is asking for trouble on the stock bottom end. But if you did spray a 150 wet kit on your current setup you could see 560ish rwhp
