Leaking Coolant, HELP
I am leaking coolant. Can't figure out where from. Once I noticed I change both upper and lower hoses and put a new O ring in the thermostat. It is dripping and hitting everything so I can't locate where its coming from. I beleive it is coming from somewher on the lower half of the engine. I rulled out the raditor and hoses. Any advice?
Tried searching but can't find anything.
You have a 98. The water pump gaskets are paper as opposed to the 99-02 metal gaskets. Its kind of hard to detect the leak directly at the gaskets due to its location. It an easy job to swap these gaskets out. My 98 leaked prefusely everytime I parked it. I got under the car & could see the fluid was coming from around the weep hole on the pump. I ended up swapping out the pump & metal gaskets. It never leaked again. There is a write up on here somewhere.
