shreveport/bossier hang out!
#745
Hey I ate me one o' those newer V6 Maximas... think they pushin' over 300... anyways it was fucked up cuz it was a husband/dad, wife in front pass. seat, and kid in a carseat in the backseat. He kept hittin' it and lettin' off, and the wife was laughing for some reason, so... kid in the back or not, I launched on his last little jump. He just hung out behind me in traffic after that. Jesus, I'd NEVER run 'em if I had my own kid in the backseat, ya know? Dumbass people.
#750
All that plus a few other things put a dent in the wallet, so it might be end of next month before the cam install. I got some prothane motor mounts, oil pan gasket, rod bolts, new plugs, 10.4mm wires, and all the rearend stuff I'm gonna install all at once. Gonna use my dad's shop for the rear since he has a two post lift.
#753
Looks good. Have fun with the parking brake assembly. Who is gonna press your axle bearings? My 9" didnt fit worth a damn. The parking brake brackets wouldnt fit on the housing, and the panhard rod wouldnt slide into it either. Hope yours was better than mine
#759
Well, i had a hard time with the parking brake. And, right now i dont have one. I actually have a spair setup of another totalled t/a. Just the way the thing is set up. The caliper bracket is what retains the axle. And with the bolts they give you its hard to grab any amount of the bolt with the parking brake setup in the way. The reluctor rings are in the way, so its hard to use a longer bolt. I could have kept the brake, but would not grab enough of the nut the bolt goes to. Seemed to me like i could keep the brake and not grab much of the nut, and possibly have the axle fall out while going down the road. Or ditch the brake and be sure. I put it in and havent went back to fix since. I just throw it in 1st when i park. Seems like a 3 channel car would have an easier time than i did. Oh, and for god sake make sure you have the caliper bracket on the axle before the bearings are pressed. I tried to have that driveshaft place on grimmit do it, made 3 trips there and back cause they wouldnt do it. They said there would be no way to get to the bolt if i did it that way. Funny thing is they were partly right. I brought it to P.A.T.C in bossier and the guy knew exactly what i was talking about. Not sure if it matters, but there is a right and left axle(different lengths) but i am not sure if the caliper brackets can be used on either side of the car. I just labled everything to make sure when i had them pressed.
