New Products Showcase Come inside to see the newest hardware!
New Products from NOS and Holley
Old 10-31-2008, 09:11 AM
LS1TECH Sponsor
Jay M's Avatar
Default New Products from NOS and Holley
NOS is proud to present our 2 Stage Wide Open Throttle/ RPM activated Window Switch with Shift Light Control. The WOT/RPM activated window switch is a small, compact, user friendly unit with features like, two fully programmable independent RPM window switches that can operate from 0 to 20,000 RPM for anything from a low rpm engine to a high revving sport bike. It has the capability to read a rising or falling throttle position sensor for accurate activations every time. The WOT/RPM activated window switch also features a programmable output to activate a shift light for on-time gear pounding shifts and a handy recall feature that shows max RPM and TPS voltage for easy set-up. Also comes in the 02121NOS, 05134NOS, and 05135NOS kits.
o Small, compact, user friendly unit with bright easy to read display
o 2 Fully programmable RPM window switches for easy adjustments without the need for RPM pills
o Window switch off and on RPM can be programmed from 0 to 9,999 RPM in 1 RPM increments for precise control (Reading is x10 for applications over 9,999 RPM)
o Works with any 4-cycle engine from 1 to 12 Cylinders
o RPM input can be connected to a DIS coil “driver” wire or a tachometer output circuit
o Will read from 0 to 20,000 RPM for use on a low RPM engine to high revving sport bikes
o Can read a rising or falling TPS signal for a wide range of
applications and precise activations
o TPS trigger voltage is adjustable from 0 to 5.0 volts in 1 tenth increment.
o Perfect for a Drive-By-Wire vehicle that has no throttle cable to mount a traditional activation switch
o Window switches work independent of TPS so the window switch is at home just as much on a carbureted vehicle as it is on a EFI car
o Shift light control is adjustable from 0 to 9,999 RPM for on-time gear pounding shifts every time
o Live RPM and TPS readings are displayed on the bright, easy-to-see display
o Handy recall feature allows the max RPM and TPS voltage to be viewed after a run
o Bright colored LED’s light up when stages are active for easy verification of activation
o Replaces P/N 15879NOS RPM Switch
o Included in popular NOS Drive-By-Wire nitrous kits
o Can also be used to activate other accessories, not just nitrous
o Priced attractively as compared to traditional switches
NOS Part Number 15982NOS. It is currently available from NOS dealers.
Old 10-31-2008, 09:22 AM
LS1TECH Sponsor
Jay M's Avatar
Default Holley Stand Alone WB Controller and Gauge
The Holley 534-201 wide band kit is the ultimate addition to any carbureted or EFI vehicle. It will accurately measure any air/fuel ratio between 10:1 and 18:1. This allows the engine tuner to read the air/fuel ratio in real time for extremely accurate tuning. Tune any carburetor through all of its circuits for ultimate power and mileage or use in conjunction with your EFI system to tune it to perfection as well.
The 534-201 can also be upgraded later for use with an NTK sensor by simply reconnecting a jumper loop and purchasing the NTK sensor (P/N 534-194).
The Holley Wide Band O2 gauge features a 3-digit numeric display along with a 40 segment bar graph. With the ultra-high intensity light emitting diodes you will be able to see your Air/Fuel ratio even under direct sunlight.
The P/N 534-201 is designed to operate in street or race environments and will withstand heat, dirt, and vibration. The Holley Wide Band O2 gauge will fit in a standard 2-1/16” gauge pod.
Controller Features
• Small weather-sealed unit for convenient mounting
• Easy Installation
• Accurately measures A/F ratio between 10:1 and 18:1
• Will accommodate a Bosch or NTK sensor
• Includes Bosch LSU4 Sensor
Gauge Features
• Features a 3-digit numeric display and 40 segment multicolor bar graph for a quick read
• Ultra-high intensity light emitting diodes for easy viewing even in direct sunlight
• Standard 2-1/16” diameter for ease of mounting in a standard gauge pod
• Built for race environments to withstand heat, dirt, and vibration
• Connects to vehicle light switch to dim the gauge during night time viewing
Old 10-31-2008, 09:40 AM
LS1TECH Sponsor
Jay M's Avatar
Default New Shirts and Hats
American Icons! Holley and Camaro are two of the biggest names in performance and racing, and both have played a major role in automotive performance history. Celebrate the re-birth of the Camaro with this special edition T-Shirt from Holley. The back features Chris Froggett artwork showcasing the new Camaro with a 1969 Camaro cleverly mirrored in the pavement below on a navy blue Hanes Beefy T-shirt. On the front, modern and vintage Holley logos show everyone that you’re serious about automotive performance!
Available under Part Number 10006-XXHOL. Replace the XX with size
World Famous! There are carburetors and then there is a Holley carburetor. And, none is more famous than the formidable Holley Double Pumper®. The Double Pumper met the demands for increased power being delivered by the factory muscle cars of the 1960s and is still doing so today! The new "Breathe Easy" t-shirt conjures images of this golden era of performance. The red and grey art contrasts perfectly against the navy blue Haynes Beefy T-shirt. Put one on and "Breathe Easy" knowing the statement on your back says you're a true hot rodder.
Available under Part Number 10010-XXHOL. Replace the XX with size
New Caps! You’re already thinking about performance parts all the time, why not share it with the world by wearing the top names in performance on your head! Check out Holley’s latest creations in casual headwear. Some are subtle, some are loud, but most have a retro feel that we have found so popular with our t-shirts. They are made of 100% cotton twill and feature a low profile design that fits snug on the average Joe. The designs are a combination of embroidery/woven labels with contrasting stitching, so they say “Performance”. Check out the pricing and you’ll agree they are a good value for this type of quality. What else would you expect from the #1 company in performance!
All of this and more is available at the Holley store http://www.holley.com/Store/
Quick Reply: New Products from NOS and Holley
