Holley Launches New Aluminum Street Avenger Carbs!!
LS1TECH Sponsor
I understand most of you guys run EFI but there are alot of LS engines with carbs!!
Holley’s Avenger series of carburetors have just been taken to the next level! Street Avenger™ carburetors are known to bolt-on and perform great right out-of-the-box. What could be better than a Holley Street Avenger carburetor? How about one in aluminum? They save weight and look great!
Aluminum Street Avengers only weigh 7.85 lbs. Not only do they save weight under the hood, but they also save weight in shipping! The tumble polished aluminum finish on the Street Avenger will keep its shine for a long time to come or it can be hand polished to a show quality shine.
The new Aluminum Avengers have the same great features as their zinc counterparts such as quick change vacuum secondaries for easy fine tuning; four vacuum ports for all necessary vacuum accessories; factory preset “No trouble” electric choke for easy start ups; built-in fuel filters; and an included fuel line kit so there are no unnecessary trips back to the parts store. Aluminum Avengers feature the same optimized street calibration as the zinc versions so you know they will run great on your vehicle. And, the Aluminum Street Avenger now comes with a clear fuel level sight glass for easy, no mess float adjustments.
Avengers are the first carburetors to have a limited lifetime warranty.
Check them out on Holley.com
http://www.holley.com/types/Street_A...-_Aluminum.asp
