New Product- Sway bar Adaptor Kit for Aftermarkert Rear Ends
Hello Everyone,
UMI Performance is now offering sway bar adaption kits for installing a stock or aftermarket rear sway bar to aftermarket rear ends. This kit includes everything needed to install a factory or aftermarket sway bar to your new rear end. Supplied with this kit is new bolt on CNC machined bushings mounts, heavy duty zinc plated chrome moly u-bolts and longer end links. This kit places the sway bar below the larger center section on aftermarket rear ends and provides proper clearance. The supplied longer end links provide the proper geometry of the rear sway in its new mounting location.
This kit is a 100% bolt in application, it requires no welding! The sway bar mounts feature CNC machined teeth designed to grip into the rear end securely fastening the sway bar in place.
More information can be found here- http://www.umiperformance.com/catalo...ex&cPath=7_114
