New Products Showcase Come inside to see the newest hardware!
AMS clutch shim
Old 10-11-2011, 09:41 AM
Larry @ AMS's Avatar
Default AMS clutch shim
The AMS T-56 Slave Cylinder Spacer is designed to adjust the clutch pedal engagement point higher off the floor when upgrading from a stock clutch to an aftermarket or LS7 clutch for your T-56 transmission. This solves the problem of the engagement point being too low off the floor which is a very common issue when installing an aftermarket clutch.
The Spacer is made to exacting tolerances from 0.125” thick 6061 aluminum, stamped with the AMS logo, and then anodized red for a durable finish. Popular in ’98-’02 Camaros/Firebirds this may also fit other T-56 applications with a 2-bolt slave cylinder.
http://www.amsperformance.com/cart/a...er-spacer.html
