New Products Showcase Come inside to see the newest hardware!
Now In Stock! Holley Mid-Rise Intake Manifold 92MM Cathedral Port 300-126
Old 01-11-2013, 10:23 AM
MikeFSKSpeed's Avatar
Default Now In Stock! Holley Mid-Rise Intake Manifold 92MM Cathedral Port 300-126
Hey whats up guys,
Just got a shipment of these in stock. Retail is $639.99, LS1 Tech Introductory price of $600 Shipped PM me for info.
Thanks! Mike
The Modular Mid–Rise intake utilizes the popular Holley LS1/LS2/LS6 cathedral port Mid–Rise 2 x 4 intake Manifold along with a purpose built plenum base Adapter and a Holley 92MM EFI plenum top which converts it into a Mid–Rise EFI intake manifold. With a max overall height of only 10.44”, the Mid–Rise Manifold is an excellent choice for street and performance street/strip applications with a powerband from 1,500–6,500 RPM and limited hood clearance. It's perfect for a blow–thru or turbocharged application. Being part of the Holley modular intake line means that this intake is not only available as a complete kit with intake, adapter, 92MM top and fuel rails, but all parts can also be purchased separately for a custom intake build. The plenum Adapter (PN 300–231) will accept all of the popular Holley Hi–Ram plenum tops as a foundation for custom induction systems.
Features:
Provides great performance to 6500 rpm for street/strip performance applications while providing the look of a racing EFI intake manifold
Unique modular design allows the combination of a traditional dual-plane layout with an EFI manifold plenum to produce great mid-range torque without compromising top end power
Great for supercharged or turbocharged engines Power band from 1500-6500 rpm
May require an aftermarket hood for some vehicle applications.
Cast aluminum construction
Intended for use on all GM LS Gen III or IV engines equipped with LS1/LS2/LS6 style cathedral port cylinder heads (recalibration of the ECU may be required when using this intake manifold design with OE ECU).
Old 01-11-2013, 11:51 AM
The Highest part of the new Holley is 10.1 " and the FAST is about 6"
If anyone needs any special pics, Feel free to ask!
Old 04-11-2013, 04:02 PM
Got a few of these back in stock, if anyone needs!
Quick Reply: Now In Stock! Holley Mid-Rise Intake Manifold 92MM Cathedral Port 300-126
