UMI Releases New Product- Rear Spring Spacers for the GM A, G and F-Body
P/N 0062, 0063, 0064
Priced at $9.99/each or $39.99/kit
UMI Performance is proud to introduce our new laser cut coil spring spacers. These simple spacers may be just the ticket to achieve that perfect stance or prevent tire rub. UMI’s zinc coated, mild steel spacers are available in 1/8” and 3/16” thickness and can be safely stacked. They provide an easy way to fine tune the rear ride height of your GM A, G and F-body. No cutting, welding or drilling required. We recommend these for fine-tuning only, and maximum adjustment amount is the responsibility of the installer. Normal installation position is on the upper perch although lower perches may have adequate height. Kit includes four 1/8” and two 3/16” spacers or purchase spacers separate. 100% manufactured, tested and raced out of Philipsburg, PA – USA.
WEB SITE LINK HERE
WEB SITE LINK HERE
