Plug N Play Customizable Dash for Your CTS / CTSV @ Hisnon Motorsports
Ever wish you could change the gauges in your car to monitor boost or 0-60 times? Want to see calculated TQ or HP? See your own 5V input? Wideband? Watch knock sensor values? Well the day has finally come where all of this can be a reality. Hinson Motorsports is proud to bring you DashLogic.
Supports all 2009-2014 CTS & CTSV models:
Video - Click Here to See How it Works
DashLogic eliminates all mounting and cutting of after-market gauges and is the most advanced way of displaying vehicle data to date. There is nothing to install, no programing, no changes to your vehicle in any way. Simply plug in the DashLogic device to your vehicles OBD-II port and DashLogic turns your factory dashboard display into a fully customizable gauge canvas. See all of the data your vehicle has to offer on your Driver Information Center or Head-Up Display.
DashLogic doesn't stop there, you can also customize visual and audible alerts that you set to any condition for any vehicle value, fully customizable by you. Just in case your car doesn't have a sensor for a value you would like to watch, DashLogic also has two auxiliary inputs so you can add up to two aftermarket sensors to be viewed on your DIC or HUD as well as be used for alerts. The DashLogic alerts system is a very advanced tool, this is not your run of the mill type of simple alert that only watches one value. DashLogic will take into account several conditions for one alert, all of those conditions fully customizable by you. DashLogic also tests your performance, use DashLogic to get your calculated HP & TQ, 0-60 time as well as your 1/8th mile, 1/4 mile, 1/2 mile, and standing 1 mile times recorded with a trap speed.
- USB interface used for configuration
- Supports all 2009-2014 CTS & CTSV models:
- Auto and 6spd manual transmissions
- See boost using the factory MAP sensor (note a 2 BAR or greater MAP is required for non-ZR1 models)
- Two auxiliary inputs for aftermarket sensors 0-5v
- 0-60, 1/8th mile, 1/4 mile, 1/2 mile and 1 mile elapsed time recorder
- Calculate Horsepower and Torque
- Selectable display location
- User upgradeable via free downloads
- ZERO permanent modifications to vehicle, unplug and resume 100% factory conditions
- Low Power Sleep mode ensures your battery will not be drained if DashLogic is left in the vehicle
- Simple Plug and Play, no software or installations required
- Dimensions: 2.25" x 1.75" (57 mm x 44 mm)
*For any questions about this NEW PRODUCT check out www.hinsonmotorsports.com or email chris@hinsonmotorsports.com
Also available for C6 Corvette, Camaro 5, 2007-2013 GM Truck Gas & Diesel, Cruze, and Solstice.
