New Products Showcase Come inside to see the newest hardware!
BMR Suspension New Product - Handling Lowering Springs for 4th Gen F-Body - SP090
Old 10-06-2016, 09:00 AM
LS1Tech Premium Sponsor
BMR Suspension's Avatar
Talking BMR Suspension New Product - Handling Lowering Springs for 4th Gen F-Body - SP090
BMR Suspension 1.25-inch Handling Lowering Springs for
Fourth Gen GM F-Body
SP090
Increase the handling capabilities and add an aggressive look to your Fourth Gen GM F-Body with Handling Lowering Springs from BMR Suspension. Manufactured from chrome silicon high-tensile spring wire, these springs are cold wound on a CNC coiling machine that can adjust the spring diameter in real time to ensure that every spring is exactly the same. These springs will drop your 1993-2002 F-Body approximately 1.25-inches and feature fine-tuned spring rates (725 lb/in front and 210 lb/in rear), giving you dramatically improved handling and an aggressive look. The BMR Lowering Springs (SP090) provide higher spring rates to keep the body flat and level in the corners, while giving you a lower center of gravity. This makes it the perfect spring for any F-Body that regularly sees the track. BMR designed the SP090 springs for handling and street performance applications. BMR also offers front (SP091) and rear (SP092) kits. Like all BMR lowering springs, the SP090 has a LIFETIME guarantee against spring sag. Available in red powdercoat for long-lasting good looks. Installation time is about 3-4 hours. Proudly made in the U.S.A.!
To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com, email sales@bmrsuspension.com, or contact them at BMR Suspension, 928 Sligh Ave, Seffner, FL 33584, 813-986-9302, Fax: 813-986-8055.
__________________
Allan Miller
President
BMR Suspension
(813) 986-9302
Quick Reply: BMR Suspension New Product - Handling Lowering Springs for 4th Gen F-Body - SP090
