Help me finish building my kit from scratch
Well guys, winter time is here and that means it's time to get to business on this nitous setup of mine. It is a direct port kit going on my 408, planning on spraying 300.
Here is what I already have:
-NX distribution block
-NX hardlines
-NX Shark nozzles
-NOS bottle
-NOS progressive controller
Here are some of the things I know I need:
-HSW accessory kit http://www.harrisspeedworks.com/shop...roductid=16984
-Fuel pressure safety switch
-FJO wideband, fuel pressure, nitrous pressure gauges
-Nitrous Outlet switch panel
What else do I need? I know solenoids, but which ones? HSW or Nitrous Outlet solenoids preferably, unless you have a reason not to recommend them.
Thanks for any help you guys can offer!
-NX hardlines
-NX Shark nozzles
-NOS bottle
Guest
Posts: n/a
Wideband
http://www.nitrousoutlet.com/catalog...roduct_id=2803
http://www.nitrousoutlet.com/catalog...roduct_id=2811
http://www.nitrousoutlet.com/catalog...roduct_id=2814
Gauges....this is what I would run.
http://www.nitrousoutlet.com/catalog...roduct_id=2887
Sending unit.
http://www.nitrousoutlet.com/catalog...roduct_id=2888
This will integrate with the wideband, and allow you to monitor Nitrous volume and pressure, A/F ratio, and allow you to program an upper and lower threshold shut down for both A/F ratio and bottle pressure.
From there a basic fuel pressure gauge under the hood is all you need.
http://www.nitrousoutlet.com/catalog...roduct_id=3455
http://www.nitrousoutlet.com/catalog...roduct_id=2193
Fuel Solenoid
http://www.nitrousoutlet.com/catalog...roduct_id=2194
