Most complete nitrous kit you could own for half the price
Guys this kit was used once on the dyno. with 4.10 gears I am afraid to spray the car. I am making 429hp off the bottle and with a 125hp shot I made 538hp if I remember correctly. Here is everything I have and it all goes together. I will split parts if I have the kit 100% spoken for.
Dynotune Wet Kit
Nitrous Outlet 78mm plate
New Dynotune bottle (2nd unit)
860 bottle heater
Dynotune purge kit w/ dual outlet kit
Dynotune 2 stage window switch
Dynotune lean air/fuel cutoff
Dynotune Command center
Autometer N2O gauge w/ 16' line
1ft line with wing nut for easy on off
Dynotune nitrous filter NEW
extra pressure switch
Custom blowdown that is adjustible with bulkhead fittings
I also have hundreds in fittings alone.
As you can see there is nothing more you can add to such a kit. Things like the command center, AF cutoff, etc... are brand new and have never been connected. I have easily spent over $2000 on this kit. The blowdown setup alone was over $100 in just fittings and line. I dont cut corners and have not in this car. I am asking $1000 for it all.
Dynotune Wet Kit
860 bottle heater
Thanks guys. I decided I am going to try something different so it can get locked up.
On a side note I like seeing the ads here because when I am looking for my Nitrous needs it is much easier to filter through here then the classifieds. In anycase glad we got Johnny Law around.
