New to Nitrous, couple of questions regarding a kit
I'm looking at the Harris Speedworks 125hp dry " Sudden Impact " kit to get for my 2001 SS. It looks like it comes with pretty much everything but being my car is a 6-speed what other safety items would I need to buy?
I know I need some TR-6 plugs but I'll need a RPM window switch too correct?
Anything else I'm missing? Also how addictive will this be?
What kind of power are you putting down NA? a 125 dry shot will most likely max out your injectors and they will need uprading.
For a complete kit you might want to check out our "all out" accessory kit. Comes with everything you would need to safely and consistently run your kit
http://www.harrisspeedworks.com/shop...age=1&featured
So I could buy the base dry kit then the accessory kit and have everything I need? Would I need a stronger fuel pump or larger injectors? I want to make this as safe as possible because I've always had a slight fear of blowing up my motor. Anyway I said screw it so now I want some extra power. Right now I'm most likely around 400 to the wheels with the cam and bolt ons. It's a Torquer V3.
I would recommend the injectors and fuel pump. As mike and Matt said you'll be close to maxing the injectors out. And anymore with these cars I almost always recommend a fuel pump with hotwire harness.
Nick
Nick
