FPSS Question
Guest
Posts: n/a
They are set according to the flowing fuel pressure of "your" vehicle. The instructions that come with the switch will out line how to set it on your car.
They usually install at the same point you are tapping into the fuel supply to get fuel for the kit. If it is a dry kit they will go on the fuel rail. They usually come with the fitting you need
