wiring guru's!!!
Old 12-11-2008, 08:37 PM
bhice's Avatar
Default wiring guru's!!!
first off i did a search.... so please dont hound me. i wired my kit in today. i have the nitrous outlet switch panel. as far as i know i do i have everything wired correctly, but when i put the ground wire on my arming switch it lights up the red led even if the system isn't armed. i have the middle prong on the switch run to the microswitch. one side of the switch (without the resistor) run to a 12 volt source. and the small prong on the other side is my ground wire. please help it has me so confused. i looked at nitrous outlet's website at the wiring diagram and it is exactly like i have it. possible bad switch??
Old 12-12-2008, 09:30 AM
ShiznityZ28's Avatar
Check your micro switch. unplug the wire coming from the middle pole on the nitro outlet panel. Does it light up now? if not unplug the wire from the micro switch and plug it back into the nitrop outlet switch. Does it light up? if yes the wire is probably cut and grounding. if not the micro switch is bad or being pressed.
Old 12-12-2008, 03:47 PM
bhice's Avatar
i found the problem. had 2 wires backwards on switch. thanks alot
