Planning for this upcoming season. Need some opinions on how much to spray
I have a 00 Camaro. Stock bottom end. PRC 2.5 5.3 heads, 595/598 cam, fast 90/90. Made 435 rwhp on stock injectors. Just got my fast 42#'s, Ordered my NX stage 6 lightning solenoids and am still in debate between hsw and nitro daves plate. Also will be getting the lingenfelter 2 step to spray out of the hole.
A level 1 six speeds inc. trans and textralia clutch backed with 4.30 gears and a moser 12 bolt will be putting it to some m/t slicks.
I was wondering a general "safe" hp limit for the stock bottom ends. I was wanting to hit it with a 150 shot out of the hole if possible or would I be better off not pushing my luck and sticking with a 100 shot. All neccasary safety stuff will be in place to. Fpss, window switch, wideband, etc. A littl advice and opinions is welcome.
I'm wanting to get as far into the 11's as possible an 10's would be awesome. Right now best is a 12.33 n/a with a shitty 2.1 60' on some nittos. Thanks
definitely get a daves plate, and a 150 would be no problem. as long as your tune is good you can hit it with a 200 and still be one. the stock bottom end should be pretty safe to about 600 rwhp as long as your tune is on point. i know a guy down here that sprayed his car with a 200 for a few years until his fuel pump died and he had no fpss. and to get high 10's shouldnt be out of reach either. good luck and be safe
daves plate is designed for maximum flow. it can hold up to a 400 shot...not that they recomend you use it for a 400, but it has the capability to do so. the quality is freakin amazing, and its just a tried and true piece of nitrous genius
