Nitrous/Fuel Sol. Setups
I want to make mine look clean under the hood, but my brain is not very imaginative... Can you post pics of your set up? I'm running the nitrous outlet 90 mm plate with the jetting on the back of the plate. thanks a ton!
Here is how I plumbed my HSW plate. I used a Nitrous Outlet MAF bracket and modified it to fit my solenoids. You can put 90* fittings on the plate and then route the lines the same way I did. Just a simple suggestion. I will eventually get around to shortening the lines a bit.
Yes it is a FPSS (I do not run that anymore). Prior to the FPSS I had a mechanical gauge.
Facing the driver is an autometer fuel pressure guage I use to log the fuel pressure.
Here is the Nitrous side. I have a dry stage that is the outboard Noid, inboard is the wet plate noid.
I found an intake bracket kit from Harris SpeedWorks, it looks good... Only hope it will work with the TB plate I'm running. Doesnt the Sol. on your head get super hot? I had mine on there for a short time but I was afraid all the heat was going to ruin the sol.
I do like your setup though! Very clean!
