question
You don't need one but it can help. If the trans shifts while you are spraying there is obviously more stress on it. If you have a window switch that shuts of a few hundre RPM before the shift point, it could prolong the life of your trans a bit. So basically, if you are on a stock tranny it wouldnt be a bad idea.
Also, pieces like our microedge controller do a lot more then just function as a window switch. So, you are getting quite a few features along with it.
Guest
Posts: n/a
IMO a window switch is a must.
We offer several different models of switchs
http://www.nitrousoutlet.com/catalog...del=86&dept=11
-Chris
