Help with my nitrous install
i got a used zex dry kit for a good deal but needed a few questions answered
first of all, im putting this on my v6 1999 3.8l camaro
im having trouble locating the tps signal wire i need to tap into
also, for the vacuum lines, im guessing im supposed to use a t fitting?
the vacuum line marked intake, does it go on the passenger side of the intake right before the MAP sensor? im not sure which line im supposed to use and dont want to mess anything up
I looked and like you couldnt find much. Your best bet would be to go buy a haynes manual and look at the pcm diagram to tell you which wire it is. Cant go wrong there.
Oh wait duh I have one let me go check for ya real quick talk about a brain fart. lol
i checked mine, and it didnt have my style in the book, it just showed the 3 wire harness, and mine has 8 wires, another guy showed me this so i think its the purple wire but would like a second opinion
edit.. idk if yall are going to be able to see the image, let me know if you cant and ill upload somewhere else
